Will you notice difference in leveling kit - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-12-2013, 07:42 PM Thread Starter
jonwalden's Avatar
I was lookin at a few leveling kits just gonna do a mini pack just wondering if you could notice the difference between the 2.7" and 3" leveling kit? Bc mine being a early 99 I need all the lift in front I can get the 2.7 is made by custom diesel
Sent from AutoGuide.com App
jonwalden is offline
post #2 of 5 Old 08-12-2013, 08:18 PM Thread Starter
jonwalden's Avatar
Any info
post #3 of 5 Old 08-13-2013, 03:50 AM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
I did a 2.5 zone kit on mine and had to add 1.5 in the rear to get it level
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #4 of 5 Old 08-13-2013, 04:22 AM
ja_cain's Avatar
This is good to know. I was looking at the zone kit also, but was not sure how it would turn out with the thicker blocks on the back. Since that is what my truck has it should be perfect with the 2.5 leveling kit. I will probably add through in some Bilstein shocks for improved ride quality.
2002 F-350 SCLB PSD 4X4 6 Speed
ja_cain is offline
post #5 of 5 Old 08-13-2013, 08:38 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Have you measured to see what height you need?
Best ride quality will always be from using a V code factory spring. You can get a hanger lift in 2,3 and 4.5" which will enhance the ride quality by giving additional travel.
If you want new springs and 2" and the best ride quality get X code springs will ride better than any lift spring.
Mini spring packs can reuse stock length shocks, hangers need longer.
Both kits require a adj track bar to recenter your axle.
The axle shifting will side load your spring bushings which will cause premature failure and doglegging.
We carry all.
Cary
CT Performance, Inc. is offline
