Fuel leaking where fuel lines go into fuel bowl - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-11-2013, 03:05 PM Thread Starter
SixOhPowerstroke's Avatar
Quoted: 2 Post(s)
I have a 99.5 7.3. Problem is there is a leak where the lines go into the fuel bowl. There is some fuel in the valley of the motor from the leak. Is there an o-ring kit or something I can get to seal this up?
2005 F-350 Reg cab Fx4 - Deleted, updated, bullet proofed. TSD tuned. 18x10 moto metal 962's, 35x12.50 federal mt's, 2'' level, mbrp exhaust, ect, ect. Western Ultra Mount 8' Plow. Money maker/work horse.
SixOhPowerstroke is offline
post #2 of 5 Old 08-11-2013, 03:28 PM
goats's Avatar
Quoted: 2 Post(s)
Dieselsite has a O ring kit for the fuel bowl.
goats is offline
post #3 of 5 Old 08-12-2013, 07:19 AM
timmyboy76's Avatar
Riffraff Diesel: Complete Fuel Bowl Seal Kit
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 5 Old 08-12-2013, 09:40 AM
blue99stroker's Avatar
Quoted: 283 Post(s)
the fuel lines use vibralock compression fittings. everything is else is o-rings. timmyboy pointed you in the right direction.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is online now
post #5 of 5 Old 08-12-2013, 11:32 AM
Ron's power stroke's Avatar
depends on what line you speak of
the rebuild kit
A complete Fuel Bowl reseal kit for the Ford 7.3L diesel filter canister 1999-2003
for the 1/4" feed lines to the heads
Parker 60VLV-4 Viton Sleeve (1/4 inch)
or the feed lines to the bowl
Parker 60VLV-5 Viton Sleeve 5/16 inch
Parker 60VLV-6 Viton Sleeve 3/8 inch
Early 99 7.3 F350 auto,TN T-4 mount with a s467 thanks to unlimited diesel..shimmed 910's, DI push rod's, new alliant 315/200 hybrids, full fuel with a fuel lab 4202,TSD sump...tuned by Gearhead..i cant wait to drop her in the truck...
88 F250 7.3 IDI plow truck - bone stock
Ron's power stroke is offline
