Don't Any Wheels Fit ???? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-10-2013, 12:34 PM Thread Starter
I have searched for F350 compatible wheels and found hardly anything. My favorites were 18x9.5 Pro Comp 6001s, 8x170, 4.5" backspace, -19mm offset.
What am I missing? Thanks
To clarify, every webiste that asks me which vehicle I have, finds nothing compatible.
mram10 is offline
post #2 of 6 Old 08-10-2013, 12:49 PM
alaskan155's Avatar
Quoted: 65 Post(s)
im assuming SRW, if so there are a ton of wheels out there for it.....
1,300 just on summit racing in a 8x170 bolt pattern
http://www.summitracing.com/search/d...tern/8-x-170mm
36 with a 4.5 back spacing and 18" rim
http://www.summitracing.com/search/d...ng-in/4-500-in
and thats just summit racing, guarantee there are more out there, try some of you local tire shops/jegs.com/4wheelparts/etc
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #3 of 6 Old 08-10-2013, 03:40 PM Thread Starter
So, there is no special parameter to look for? Example, I had a bmw 525i and the pattern was easy to find, but the hub diameter for the wheels were very hard to find.
mram10 is offline
post #4 of 6 Old 08-10-2013, 04:10 PM
Quoted: 17 Post(s)
I wouldn't worry about the hub diameter. Most are large enough cause the 05& later have a larger hub hole. If you are worried about them being hub centric them you can get adaptors made.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #5 of 6 Old 08-10-2013, 04:15 PM
alaskan155's Avatar
Quoted: 65 Post(s)
your talking about hub centric rims,
the factory rims on a sd are hub centric, and use this style lugs,
see how they are flat.
basically the rim centers to the hub
if you go with a aftermarket rim, they are more than likely going to use acorn style lugs,
which they center the rims, allowing the hub hole to be larger on aftermarket rims,
if you run the accorn style rims, then you will need to carry factory lugs for the factory spare if you plan on keeping it,
also the super duty's are the only vehicle i know that uses the 8x170mm lug pattern, i think dodge and chevy use the old 8x6.5 lug pattern
if you are worried about the gap in the hub with new rims they sell hub centric rings that fill in the gap, but they are not needed.
the blue ring, fills the space
post #6 of 6 Old 08-10-2013, 08:04 PM Thread Starter
Thanks again guys.
mram10 is offline
