How long to make oil pressure? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-10-2013, 11:55 AM Thread Starter
I know these trucks will cut off if they don't make oil pressure within a set amount of time...
My question is how long does it usually (or should it) take? I feel like mine takes awhile. I know its only a few seconds but it seems like sometimes I'm watching it and expecting it and wondering if its going to make it.
Pipewrench is offline
post #2 of 4 Old 08-10-2013, 12:43 PM
Mine does the same thing. Usually takes a few seconds for the oil pressure light to go off.
99' Powerstroke is offline
post #3 of 4 Old 08-10-2013, 07:40 PM
Mine has been doing that as well. I never noticed it until after I had the turbo of and was a little worried that maybe I had a leak at first. So I am always watching it close now and it always has me worried. No problems yet though.
Matthews is offline
post #4 of 4 Old 08-11-2013, 12:40 AM
The engine won't run unless it has oil pressure. There is enough oil in the HPOP reservoir to run for a little while but the LPOP should fill it quickly as it is a direct feed to the HPOP. Could be (partially) clogged oil pressure sender from dirty oil causing a delay in the reading
hydroman is offline
