Magnefine Trans Filter... YEs or NO? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-10-2013, 03:50 AM Thread Starter
chrispaine's Avatar
I picked on up and then was looking for info on flow direction in the trans cooler lines and figured I would throw it in there when I did the 6L cooler install. While looking for flow direction in the cooler lines I noticed a few guys on the forums saying they wouldn't use them if they were free and also noted that they have been known for over heating trannys.
Any incite?
thanks.
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #2 of 11 Old 08-10-2013, 04:36 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
I have one on my truck and I have had no issues. Hottest transmission temp I have seen was 164 on a 100 degree day. The filter definitely seems to do its job, when I dropped the when to change the fluid, it looked clean enough to eat off of. I must say I was very impressed. I change it out on an annual basis 25-30k miles or so.
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #3 of 11 Old 08-10-2013, 05:10 PM
hansel's Avatar
Quoted: 97 Post(s)
I was using on until I read some articles that changed my mind, one being that Brian from BTS doesn't recommend using them. I changed my fluid every 16,000 miles because I tow alot, so I'm not going to give the fluid enough time too get dirty. Magnafine does recommend something like 12,000 mile intervals.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #4 of 11 Old 08-10-2013, 06:00 PM Thread Starter
chrispaine's Avatar
I was looking for some of the bad reviews but can't seem to find any, one the the reasons for this post!
I think I am just going to wait and get a kit like the spin-on dieselsite sells.
For the little extra cash up front = better/cheaper filters. Was thinking about just piecing one together but when supporting vendors like Dieselsite.com and Riffraff.com do the leg work and sel the stuff for decent/great prices and then support the hobby/job of owning these old (and new) trucks its worth a few extra dollars.
Anyway bran new 1/2" magnefine for sale!!!
On the way--
post #5 of 11 Old 08-11-2013, 03:58 PM
hansel's Avatar
Quoted: 97 Post(s)
It's Murphy's law, I one night found a thread and seemed like alot of guys where trashing the Magnafine filter like they do a K&N filter. Now I can't find it too save my life
I'm all about doing whatever I can too make my truck last as long as possible, that's why i change the fluid more frequently than years ago, something about spending almost $5000 on a new transmission when if I had changed the fluid more often and had a 6.0L cooler I bet my stock tranny would still be going
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #6 of 11 Old 08-11-2013, 06:47 PM
Some of the later years of the 4R100 had a Magnafine filter from the factory. They actually have the Ford logo on the body of the filter. Mine is the 1/2" version for less restriction and the have a built in pressure bypass if it gets clogged.
hydroman is offline
post #7 of 11 Old 06-12-2014, 08:40 PM
heykw's Avatar
I thought the 7.3 had 3/8 tranny lines?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #8 of 11 Old 06-13-2014, 05:02 AM
hansel's Avatar
Quoted: 97 Post(s)
They are but if you swap out for the 6.0L cooler it has 1/2" lines, so maybe that's where he has is plumbed in.
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #9 of 11 Old 06-13-2014, 07:10 AM
Vannnce's Avatar
Quoted: 13 Post(s)
i just found one on my truck the other day, god knows how long its been there.. guess ill buy a new one and replace it. But ive never had any ill effects of it..
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #10 of 11 Old 06-13-2014, 07:48 AM
BryceB's Avatar
Ford no longer uses or recommends them.
when I got my HD4R100 installed, one was not installed. I thought the dealer that installed it screwed up and was BSing me about them not using them anymore (it was on the install instructions for these transmissions at one point). I spoke with someone at Ford Customer Service and they confirmed that they no longer used or recommended them. Their reason was that people did not realize they were there or they never bothered changing them and they would eventually clog, causing the transmission fluid flow to use the by-pass line with an end result of overheating.
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
