01 7.3 recently having trouble starting - Ford Powerstroke Diesel Forum
post #1 of 15 Old 08-09-2013, 06:41 PM Thread Starter
Jay1823's Avatar
My truck has 253k on it and just over the last 2 weeks it's having some hard time starting intermittently. Sometimes it'll start right up like normal, I can drive somewhere like a gas station for a couple minutes and go to restart it and it will just crank and crank. and just today I was about 40 miles from home and I could not get it started at all, just kept cranking. I didn't want to do it but I had to give it a shot of ether to get it to turn over. What could be my problem, I have to get this sorted out quick, I'm a contractor and my truck is my lifeline...and my only transportation. Thanks
Jay1823 is offline
post #2 of 15 Old 08-09-2013, 08:01 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
When was the last time you changed your oil and checked your fuel filter? Are you stock?
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 15 Old 08-11-2013, 04:16 PM
Quoted: 763 Post(s)
ICP IPR or HPOP may be getting weak, injectors also.
Corey@CNCFAB is offline
post #4 of 15 Old 08-11-2013, 04:27 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
My vote goes for cps
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #5 of 15 Old 08-28-2013, 06:29 AM Thread Starter
Jay1823's Avatar
My first thought was oil and fuel filter which I did just recently change since it was due but the problem still persists. Hucorey those abbreviations mean nothing to me, gonna have to help me out a little more. I do have a spare cps that I bought seeing as I read they are prone to sudden failure. What I've noticed is it mostly happens after the trucks been running, I shut it down to go into a convenience store or something real quick and go to start it back up. In the morning it cranks right over, no issues.
Jay1823 is offline
post #6 of 15 Old 08-28-2013, 06:31 AM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
Common Acronyms<--link
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #7 of 15 Old 08-28-2013, 06:56 AM Thread Starter
Jay1823's Avatar
Thank you very much
Jay1823 is offline
post #8 of 15 Old 08-28-2013, 06:34 PM
Quoted: 763 Post(s)
Where are u at in Michigan? I'm near Toledo.
post #9 of 15 Old 08-28-2013, 06:44 PM Thread Starter
Jay1823's Avatar
Richmond, about 30 miles north of detroit
Jay1823 is offline
post #10 of 15 Old 08-29-2013, 02:23 AM
Quoted: 763 Post(s)
Your going to have to get a monitor and read your Injector Control Pressure and HPOP duty cycle. Most inexpensive route is order a Bluetooth adapter at amazon $25 and buy the $5 app torque pro if you have a android smart phone.
When you try to start and it doesn't, does the tach move or sit at zero? If zero prolly another cps or small short in the cps wire.
