Oil and Filter question. - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-08-2013, 04:06 PM Thread Starter
Hey guys first off love the forum! i just recently bought a 2001 F350 6 speed with 281000 miles on it. the guy i bought it from just had the oil changed around 500 miles ago and used rotella but couldnt remember which weight. i noticed there was a small oil leak coming down the oil filter and when i checked it it was a full turn loose so i tightened it back up and hopefully it fixes the leak. anyway the truck is reading a little low. this is the first diesel i have ever owned and was wondering what weight to put in the truck.
Also i have read there are two fuel filters on the truck, one on the motor and one on the frame somewhere. if so how hard is the one on the frame to change?
Thanks for the advice!
cb11216 is offline
post #2 of 9 Old 08-08-2013, 04:41 PM
Quoted: 17 Post(s)
Feedback Score: 3 reviews
15w-40 for motor oil. factory 7.3s only have a fuel filter on top of the motor. some people do what is called a hutch mod(which adds another filter on the frame).
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 9 Old 08-08-2013, 05:08 PM
usnavyad's Avatar
Yeah rotella 15w-40 but he may have added syn as well 5w-40 it's t6 I ran that in both my 7.3ls and now my 6.0l
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #4 of 9 Old 08-08-2013, 07:10 PM
HERCULES-550's Avatar
Quoted: 4 Post(s)
Garage
I run Rotella 15w40 with a gallon of full synthetic 5w40. Motorcraft 1995 filter. I change every 5k miles. It got too expensive here in FL to do at 3500 miles. Oil and filter is $70... Let me know if anyone goes longer between changes. FYI, you can sign up for the Shell points when you use Rotella oil.
HERCULES-550 is offline
post #5 of 9 Old 08-08-2013, 11:48 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I run 15w40 Rotella from about March to November, in the winter I drop to 10w30 Rotella (diesel rated not regular 10w30). Dropping to 10w30 means I can start down to -25C ( which I regularly have to) without being plugged in, starts up like nothing.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #6 of 9 Old 08-09-2013, 01:20 AM Thread Starter
thanks for the input. i guess i can stick with 15w40 all the time i live in tn and it rarely gets below 25-30 degrees here. i plan on changing my fuel filter today, was told go with motorcraft, and the diy air filter. not sure yet if i want a tuner for it or not its my daily driver and i haul a 12ft trailer with mowers. any suggestions about if i should get one or not would be great.
cb11216 is offline
post #7 of 9 Old 08-09-2013, 03:09 AM
usnavyad's Avatar
I have been tuning t6 year round in all my diesel 5k intervals not one prob
GPDA's other shawn
usnavyad is offline
post #8 of 9 Old 08-09-2013, 03:11 AM
usnavyad's Avatar
I would def get a tuner all the tuners are great I tried a bunch of them my 7.3ls loves bills tunes with a ts 6 pos
GPDA's other shawn
usnavyad is offline
post #9 of 9 Old 08-09-2013, 04:54 AM
Quoted: 18 Post(s)
Send a message via AIM to rufushusky
On a 7.3 there is only one fuel filter on the top of the engine in the valley. The 6.0 has one on top of the engine and on the frame rails.
You can mix CJ4 10w30, 5w40 or 15w40 without any problems so whatever you can get your hands on to top off. Honestly if it is only a quart or two your engine won't notice a differ if you dump almost any motor oil in there.
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
