rearend jumping - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-08-2013, 12:02 PM Thread Starter
Question rearend jumping
I have a 99 F-350 DRW 2 wheel drive that seems to have a jumping feeling when I back up. I have a 4:10 limited slip and was wondering if the clutches in the rearend is causing this. And what would be the fix for this?
LOSTAT99 is offline
post #2 of 8 Old 08-08-2013, 12:55 PM
Quoted: 27 Post(s)
How many miles?
Have you checked the fluid lately? Not positive for our rear ends but most limited slip applications take a special additive to work "properly".
Id check your fluid, drain it and see if you have any metal shavings also. Could have lost a tooth which is only binding in reverse.....
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #3 of 8 Old 08-08-2013, 01:25 PM
Jerrybizzle's Avatar
Quoted: 23 Post(s)
Only in reverse? My linkage was loose when I bought my truck, but that made the rear end shift when starting in drive or reverse.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #4 of 8 Old 08-08-2013, 04:54 PM Thread Starter
I checked the Oil level and it was down a little, I topped it off with the correct fluid but it seems to be getting worse. And I only notice it in reverse. Thanks for the reply's
LOSTAT99 is offline
post #5 of 8 Old 08-08-2013, 04:55 PM Thread Starter
I've been feeling this for about 6 months, but it's more noticeable now.
LOSTAT99 is offline
post #6 of 8 Old 08-09-2013, 07:37 AM
Quoted: 27 Post(s)
Its unfortunate but the only way you will probably find out is to pull the diff cover and see whats goin on in there. Too many things that could go wrong in there to just take a guess at sumthin you cant even see. At least its not a drop out third, then you would have to pull the axles.
post #7 of 8 Old 08-09-2013, 12:52 PM
Quoted: 768 Post(s)
Not exactly sure on the dually axle, but are your e brakes inside the rotor like the SRW. It could be you ebrake shoes??
Corey@CNCFAB is offline
post #8 of 8 Old 08-11-2013, 03:33 PM Thread Starter
I removed the cover and drained all the old oil out, went to the dealer and picked up a bottle of friction modifier and 5 qts of the recommended oil. I rolled the tires while looking inside but I didn't see anything , No metal shavings so I closed everything back up and add the friction modifier and the oil and have since drove it around 70miles and everything sounds good now, maybe just needed fresh oil, don't know, Thanks for all your help,
LOSTAT99 is offline
