2002 f250 7.3 4 x 4 Good deal? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-07-2013, 09:33 PM Thread Starter
Quoted: 3 Post(s)
Im about to pick up a 02 f250 4x4 crew cab with 133k for 14k. Lifted and some rims but that's about it. Maintained at dealer however i dont have all the records. Does that sound like a good deal?
I posted in another section but can someone help me with an oasis report?
2005 6.0 PSD Excursion, 2015 Front End, Mirrors, ARP Headstuds, BPD HD Oil Cooler w/Cold Weather Bypass, BPD Water Pump, BPD EGR Cooler
sw20td06 is offline
post #2 of 5 Old 08-08-2013, 12:33 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 17 Post(s)
Youre a year too late for an Oasis. It has to be within a ten year period. Do you have any photos? The details are pretty generic.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is online now
post #3 of 5 Old 08-08-2013, 07:48 AM Thread Starter
Quoted: 3 Post(s)
That sucks. I'm completely new to Ford and diesels, but reading the forums, I've decided the older 7.3 and 4 x 4 was the way to go. I did get some service history from the seller, however I would have liked the whole history. He told me he serviced it at Ford every 5k miles and from the records I do have, looks like he did. Here's the following specs:
2002 F250 7.3 4 x 4 Crew Cab
One owner
Lifted (don't know what kind of kit nor does the seller)
17 Moto Metal Rims with relatively good tires
Everything else all stock with 133k miles
Brake Controller
Fifth Wheel Hitch
Tool Box
New batteries with the last year
Exterior is immaculate and paint shows good for its age
The owner said it was used for towing his fifth wheel and boat. I have no reason to doubt him with that amount of low miles for a car this age. KBB is right about 13800 or so in good condition. It has a clean CA title. Motor sounds and runs good, however I haven't done any compression check, oil analysis or anything of that nature. No leaks of any sort and there is no residue and underbody looks very clean. There are no lights on the dash that are on and everything works as it should with the exception of a stuck rear door actuator. Anyway, he is selling for 14k firm. Attached are some pics. My goal was to obtain a 7.3 4 x 4 Crew Cab in relatively stock condition that has been maintained. You think it’s a good deal?
ID:	151602   Click image for larger version
sw20td06 is offline
post #4 of 5 Old 08-08-2013, 07:51 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
how much are they asking?
2000-7.3L is offline
post #5 of 5 Old 08-08-2013, 07:55 AM
Quoted: 6 Post(s)
Originally Posted by sw20td06 View Post
That sucks. I did get some service history from the seller, however I would have liked the whole history. He told me he serviced it at Ford every 5k miles and fromt he records I do have, looks like he did. Here's the following specs:
One owner
All stock with 133k miles
Brake Controller
Fifth Wheel Hitch
The owner said it was used for towing his fifth wheel and boat. I have no reason to doubt him with that amount of low miles for a car this age. KBB is right about 13800 or so in good condition. It has a clean CA title. Motor sounds and runs good, however I haven't done any compression check, oil analysis or anything of that nature. No leaks of any sort and there is no residue and underbody looks very clean. Anyway, he is selling for 14k. Attached are some pics. You think its a good deal?
Doesn't sound like a bad deal, I'd try to get them to $12k though.
Really? I was able to pull an Oasis on mine back in March when I bought it?
2006 F250 CC/SB 6.0 Diesel
SCT 3015, Straight Piped
2002 F350 CC/SB 7.3 Diesel- SOLD
-PHP Hydra, 6637, Diamond Eye DEP-510215 Muffler Delete, GlowShift Triple Gauge Cluster.
-Plans: JW Valve Body & 6.0 Torque Converter/Cooler
bikeluver43 is offline
