New to Forum- got a couple questions - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-07-2013, 11:38 AM Thread Starter
I've recently purchased an '03 with the 7.3 with 206K miles. Injectors and harness were replaced about a year ago. I installed an 8" lift, 20" wheels with 35" tires, an EDGE programmer, and a CAI. New tranny and torque converter immediately followed. Turbo back exhaust to be installed within the next few weeks.
1. Even with the 100hp program, truck seems like a turd compared to any of the other diesels I've owned-the 6.0 ford, the 5.9 dodge, and the LLY chevy. It's just slow. . .and the torque, in comparison, is disappointing pulling 12k lbs.
2. Without the EDGE, truck has a significant amount of black smoke. . .barely passed the visual part of the smog test. With the EDGE, the black smoke is ridiculous...I have to gently roll into the throttle, or there's a cloud.
3. I have to crank 4-5 seconds for it to start, warm or cold.
Mileage is right at 10. I'm guessing that all 3 of the above issues, as well as my lack of mileage, are related. I've searched this forum, without any luck or conclusion. . . anyone have any ideas on where I should start?? I appreciate the help- thanks!
bmjt7109 is offline
post #2 of 10 Old 08-07-2013, 01:10 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
could be an oil related issue.
you could also have a boost leak.
do you have any gauges?
p.s. edge is not everybodys favorite choice. their tuning is lacking.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #3 of 10 Old 08-07-2013, 01:33 PM
SuperCrutyPS's Avatar
Quoted: 298 Post(s)
Garage
Have you changed the oil / filters (oil and fuel)?
Is your turbo spinning well?
I agree with blue99stroker, you should have some type of monitoring to know what's going on. Gauges, Scangauge, or ???
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #4 of 10 Old 08-07-2013, 01:44 PM Thread Starter
Thanks for the response. . .the oil was changed right before I purchased the truck. I checked, it looks fine, and the level is where it should be. I've not changed the fuel filter- but will. Not sure if there's a boost leak- I looked, and don't see soot build-up at any of the connections. I'd agree, gauges are important- they are on the short list. I think I've got the EDGE sold. . .I've not heard great things.
I see you're from Chico. . . I miss living up there!!!
Thanks again. . . any and all input appreciated.
bmjt7109 is offline
post #5 of 10 Old 08-07-2013, 01:46 PM Thread Starter
Seems to be. . . no boost gauge yet. Hopefully soon!
bmjt7109 is offline
post #6 of 10 Old 08-07-2013, 05:33 PM
Quoted: 2 Post(s)
I am also new to the forum, and diesels, and have found this forum very helpful. My truck is stock, but I have an Edge Insight that I use as gauges. Check your IPR and ICP - could be causing mileage/hard start/performance issues. Also check the EBP sensor and tube. I checked mine and it was plugged and the tube was cracked. I am hoping this solves my fuel economy issue. Also, build yourself a boost leak tester and check for leaks. I found several small ones that I hope will improve mileage and performance.
inspectorCSS is offline
post #7 of 10 Old 08-07-2013, 06:45 PM Thread Starter
Thanks. . .I've got some more research to do. . .everything I find on here is an acronym!!! IPR and ICP??? I watched the video on the EBP sensor and tube- learned what the EBP stood for- gotta learn the rest of the acronyms!!!!!
bmjt7109 is offline
post #8 of 10 Old 08-08-2013, 04:12 AM
Quoted: 247 Post(s)
ya their is a ton of acronyms lol
ipr is the injection pressure regulator, icp is injection control pressure. both of these sensors deal with the oil side of the injection system.
ya im a native chicoan. it is a great place to live. too bad you dont live here anymore i could give you some help.
post #9 of 10 Old 08-08-2013, 12:38 PM
[QUOTE=bmjt7109;6211698]1. Even with the 100hp program, truck seems like a turd compared to any of the other diesels I've owned-the 6.0 ford, the 5.9 dodge, and the LLY chevy. It's just slow. . .and the torque, in comparison, is disappointing pulling 12k lbs.
You cannot even compare the 7.3 to the 6.0 if you wanted speed. No way the 7.3 will ever be as fast as a 6.0 without thousands of dollars in mods. That being said the 7.3 is like a draft horse, slow and powerful. You have a very solid motor that will pretty much pull what ever you have. That being said do all the above have said, freshen everything up: Oil and filter change (t6), fuel filter change and air filter and she should be good to go IF there is no problems. Good luck with her.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #10 of 10 Old 08-08-2013, 07:51 PM Thread Starter
[quote=NCDeerHunter;6224082]
I'd agree with you there!!! Thousands to make the 7.3 a little faster, or thousands to make the 6.0 dependable. . .I had 2 different 6.0's, and both were problematic from the start. When they ran, they were fantastic. I heard great things about the 7.3, and mine has a significant amount of miles. I'll attack the recommended fixes, hopefully starting this weekend. My biggest concern is the amount of black smoke. . . seems to be wasting lots of fuel! Thanks a bunch for the input.
bmjt7109 is offline
