extra fuel tank in bed - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-05-2013, 05:36 PM Thread Starter
Quoted: 16 Post(s)
Feedback Score: 3 reviews
who uses/used them? i think i want a 40-50gallon tank in the bed that gravity feeds my stock tank. i don't need it everyday but it would be nice on trips as alot of places we go don't have good fuel, plus prices vary. i do have an in the bed tool box so the tank would have to go behind it, i think this holds me back more than anything. i thought about an excursion tank where the spare is but then no spare
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #2 of 11 Old 08-05-2013, 08:48 PM
Quoted: 17 Post(s)
I have an Excursion & its nice having 44 gallons but sucks when you fill it up
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #3 of 11 Old 08-05-2013, 11:44 PM
JSchuricht's Avatar
I have one in my 00, it's a aux tank. What your describing is a transfer tank. The main difference is how fuel gets out of the tank and into the engine. Transferflo makes a toolbox/tank combo. There are also L shaped tanks that are designed for a tool box to sit ontop of or you can find a slim one to fit in front of the toolbox.
I prefer the aux tank setup. It uses a 6 port valve to switch the feed and return lines between tanks. When the valve is switched, the fuel gauge also switches.
With a transfer tank, there are kits you can get with a check valve for gravity feed or even a pump that you turn on to fill the main tank.
Another option is replacing your existing tank, there are a few manufactuors that make tanks around 60 gallons but they are expensive.
JSchuricht is offline
post #4 of 11 Old 08-06-2013, 02:27 PM
Quoted: 27 Post(s)
Id rather have a spare floating around in my bed that i can remove whenever than have an auxilary tank taking up room. But thats just me and i haul a lot of crap in my bed. I have 35's so my stock spare is useless so i just have a spare in my bed at all times. If i need the bed space i just take it out and put in the cab or leave at home if just going short distances.
I would either get a 60 gallon tank or ad the excursion tank.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #5 of 11 Old 08-06-2013, 03:08 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I was thinking about having a "custom" tank built that would go under my bed box. I figured it out to be around 32 or 38 gallons of available space.
I just did a recent road trip and was not reeley pleased with the miles between fill ups.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 11 Old 08-06-2013, 11:45 PM
JSchuricht's Avatar
If you decide to go custom, KSH marine in Arizona is who made mine a few years ago. They were a little slow in getting the tank done but otherwise I am happy with it.
post #7 of 11 Old 08-07-2013, 12:46 AM
alaskan155's Avatar
Quoted: 60 Post(s)
how many gallons is that beast?
and this is the one i have been eyeballing, one of deezee's combo tanks
Combo Transfer Tank - Black Aluminum
if you already have a tool box they sell the L-shapped ones
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #8 of 11 Old 08-07-2013, 10:42 PM
JSchuricht's Avatar
155 gallons.
post #9 of 11 Old 08-08-2013, 02:22 AM
CSIPSD's Avatar
I run a 105g L tank... Its a transfer tank, but just remove the plug, add a valve and plumb it into your filler neck.
I use 1/4" fittings and hose, welded a bung into the filler neck.
I cant remember the last time I took the factory filler cap off. It gravity feeds into the main tank, and when the pressure equalizes it stops. Only time I ever turn the valve off is when both tanks are VERY full and its hot out. Then it can from time to time leak out the top of the tank.
I have had EVERY truck I have ever owned set up this way... 95, 96, 97, 99, and my 2001.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #10 of 11 Old 08-08-2013, 10:40 AM Thread Starter
Quoted: 16 Post(s)
Tradesman 37-Gallon Liquid Storage Tank — Black | Auxiliary-Transfer Tanks| Northern Tool + Equipment
This is what i had in mind. They do not recommend to use it as a transfer tank but i can't find a transfer tank that stands up.
I never thought about pumping it straight in. I just assumed i would have to have a cut off valve and manually work it
