Thank you to everyone that contributes to this forum - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-05-2013, 01:44 PM Thread Starter
Quoted: 2 Post(s)
Being new to diesels, I registered on powerstroke.org to learn as much as I could as quickly as possible. I recently purchased a 1999 F250 super duty in a package with a 5th wheel trailer. The truck runs fine, but seemed to use a lot of fuel. So off to the forums I went to see if there was anything that I could check
Consistently everyone said the EBP sensor and tube as well as boost leaks. Following info on the forums I built a boost leak tester and found a few leaks at the intercooler, turbo and the drivers side intake. Then it was time to check the EBP sensor and tube. The tube was cracked and plugged, the coupling was plugged as well as the sensor.
So tomorrow, I will order a new tube - I know I could make one, but I don't have the tools and have not had a lot of success in the past with flaring.
Thanks again to everyone that contributes. Without your help, I am sure that I would have been looking at a very large bill from the mechanic.
inspectorCSS is offline
post #2 of 3 Old 08-05-2013, 01:58 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
This site has an incredible wealth of information and a healthy comradery among members. Welcome to the Family
There's a certain addiction that will set in. Since you've broken the ice with your rig, I'm sure it's knocking on your door.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 3 Old 08-05-2013, 03:41 PM
JK23112's Avatar
I was contemplating the purchase of an F-250 diesel pickup truck few years ago and learned a ton of stuff from this forum. Although I ended up buying a used Silverado half-ton (a gasser, of course), I know that I would someday like to own a diesel truck. I drive big rigs at work and used to own an old Navistar step van with the 7.3 IDI engine, so oil burners are in my blood.
You will find TONS and TONS of information here - and learn things you never even thought to ask about before. There are truly some experts here!
Even though I am not {yet} a Powerstroke owner, I often read a lot of the informative posts here. It is addictive, to say the least.
~ Trucker by trade ~
2008 Sterling Acterra 3-axle straight truck (240-hp Cummins ISC)
2006 International 8600 tractor (350-hp Cummins ISM)
"If I passed you on the right, you're in the wrong lane!"
JK23112 is offline
