DIY intake question - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-05-2013, 12:21 PM Thread Starter
DIY intake question
I finally swapped my AFE intake for the DIY using the WIX equivalent of the Napa 6637. I used the stock intake tube and a section of 4 inch exhaust pipe. The stock tube is a little big for the 4 inch pipe and has probably a good 3/16 inch of play. Has anyone else noticed this loose fit? I just coated the tube with some grease and tightened it down hoping that the grease will fill any small voids. I was also thinking about wrapping the 4 inch pipe with tape to make it a little bigger.
99' Powerstroke is offline
post #2 of 10 Old 08-05-2013, 12:51 PM
Quoted: 27 Post(s)
I wrapped my pipe with a bit of electric tape and that worked great. I ran it without any tape or grease for a while till i needed to do some maintenance and then remembered it wasn't a snug fit but at that point there was no dust or anything that made me think it wasn't working the original way.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #3 of 10 Old 08-05-2013, 01:50 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
Im not sure of how much grease you used but I'm hoping it doesnt make way to your turbo
I would consider another method for long term use.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #4 of 10 Old 08-05-2013, 02:39 PM Thread Starter
I just used a light coat and wiped away any excess. I'll probably tape it up the next time I take it apart. I'm glad to hear it wasn't sucking any noticeable dust anyway.
post #5 of 10 Old 08-09-2013, 03:38 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
I have done the diy intake/6637 filter mod on at least 4 trucks and never had an issue just tightening down the hose clamp. The rubber hose seems to compress enough but I've also never had one as lose as you talk about.
I like the 'couple layers of black tape' idea. Should work. Just check both hose clamps every time you change oil. I have had the clamp at the filter come lose on the wife's Excursion.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #6 of 10 Old 08-09-2013, 12:33 PM Thread Starter
I spent the 5 minutes to wrap the pipe with electrical tape and it was a much better fit. As far as the clamp at the filter goes, I used a similar type clamp that's used for the intercooler boots (I forgot what they're called) because the rubber on the filter is really thick and hard and I didn't think a regular hose clamp would be beefy enough to handle the job. The rubber portion of the filter also has somewhat of a taper to it, at least it does on my WIX filter.
post #7 of 10 Old 08-09-2013, 12:35 PM Thread Starter
If I remember right, I used a 4 1/2 inch clamp and it fit perfectly.
post #8 of 10 Old 08-10-2013, 10:41 AM
A t-bolt clamp really helps seal that connection.
Riffraff Diesel: T-Bolt Boot Clamps
weekendwarriorfsw32 is offline
post #9 of 10 Old 08-10-2013, 11:41 AM Thread Starter
Yep, that's what it was called...just found the receipt for it.
post #10 of 10 Old 06-10-2014, 03:21 AM
McKinneyMike's Avatar
What is the diameter of these t-bolt clamps? Will a 4 1/4" or a 4 1/2" work? RiffRaff doesn't list them anymore but I found another source for t-bolt clamps.
2000 F250 SD 2WD 7.3L
RiffRaff billet compressor wheel
PHP Hydra
4" Diamond Eye, turbo back w/5" tip
ISSPRO EV2 Pyro, Trans Temp, Boost and Fuel Press
Kenwood Exelon/Focal/Image Dynamics/PPI
McKinneyMike is offline
