4x4 help!! - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-05-2013, 12:37 PM Thread Starter
4x4 help!!
Hey Everyone. I'm new to the forum! I have a question. I have never tracked my excursion before but every time I launch my truck I get A LOT of wheel spin. I want to run the best time I can, with the most traction possible. Does anyone know if I launch in 4x4 low, since its on the fly and you aren't supposed to go over 55 mph in 4x4, if after I launch, can I turn 4x4 off wide open throttle? I don't wanna break anything. Can I turn four wheel drive off at wide open throttle? Thanks! Sorry of this is confusing lol
-Kyle
03excursion30 is offline
post #2 of 14 Old 08-05-2013, 12:38 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
auto or manual Tcase?
2000-7.3L is offline
post #3 of 14 Old 08-05-2013, 12:45 PM Thread Starter
Auto transfer case
post #4 of 14 Old 08-05-2013, 01:04 PM Thread Starter
Auto transfer case
post #5 of 14 Old 08-05-2013, 01:17 PM
Quoted: 13 Post(s)
Feedback Score: 3 reviews
No. You have to be in neutral to shift in/out of low
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #6 of 14 Old 08-05-2013, 01:29 PM
2000-7.3L's Avatar
post #7 of 14 Old 08-05-2013, 03:46 PM
Quoted: 17 Post(s)
I think you can shift 4hi to 2 hi up to 55 but not shift above those speeds. You tractor pulling or drag racing? Personally I wouldn't use 4wd & launch cause your likely to blow the transfer case to pieces doing so. If not that than take out other components in you front drive train.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #8 of 14 Old 08-05-2013, 03:50 PM Thread Starter
I was going to drag it. I'm curious of what it could run. Every time I do boosted launches on the street at a light or something I spin A LOT, so I didn't know if I launched it in 4 wheel drive, if I could put it back in two wheel at wide open throttle without blowing anything to pieces? Thanks
post #9 of 14 Old 08-05-2013, 04:11 PM
03Cody's Avatar
I have run my truck numerous times down the track in 4hi. It does just fine and I don't think it hurts it. I usually launch at about 10-12 lbs of boost to and haven't broke anything yet lol. I def wouldn't do It in 4lo tho. That would tear up the transfer case I believe. And when under a load the transfer case won't shift anyway so just go 4hi and have fun!
-Cody-
03Cody is offline
post #10 of 14 Old 08-05-2013, 04:56 PM
tracks are typically stickier than streets. feather the throttle. Ask people at the track for advice if its your first time, test run and see what happens
2003 Ford F-350
7.3 Powerstroke!
8 inch BDS lift.
4 inch MBRP Exhaust
Intake
Edge Juiced w/ Attitude.
40 inch tires on 20 inch Black Moto Metals.
Preston16 is offline
Tags
4x4
