another bad water pump - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-04-2013, 03:46 PM Thread Starter
blue99stroker's Avatar
Quoted: 247 Post(s)
so came out today to see some drops under my truck.
leaned down and smelled it and its coolant.
just had the the water pump replaced less than 20k miles ago.
and about 3k miles ago i put in fleetrite elc.
i have the billet dieselsite thermo housing which isnt leaking.
the leak is coming from above the bottom pulley. i think its leaking from the weep hole. which is designed to leak when the pump is bad.
so any ideas why my water pump is going bad already?
im going to the shop that did it on monday to see what they are going to do for me. considering it took them three different times to fix the fuel leak on my dads 2000 7.3.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #2 of 12 Old 08-06-2013, 08:14 AM
timmyboy76's Avatar
That should a been a flag, for the competence of that shop...
If you got about 4hrs, replace it yourself...Been using the AIRTEX now (knock on wood), for last 80k
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 12 Old 08-06-2013, 10:57 AM
chrispaine's Avatar
When my next part store lifetime warranty pump fails I will switch to the International pump with the built in filter!
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #4 of 12 Old 08-06-2013, 11:12 AM
Quoted: 13 Post(s)
Feedback Score: 3 reviews
Got a link?
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #5 of 12 Old 08-06-2013, 11:25 AM
rascal's Avatar
I would recommend going with a coolant filter when you put the new water pump in. DieselSite has a good coolant filter.
Also, they carry a lifetime warranty on their water pumps.
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #6 of 12 Old 08-06-2013, 02:03 PM Thread Starter
Quoted: 247 Post(s)
ya i had to have them replace it cause i had nowhere to fix it during the winter.
didnt feel like doing it in the rain lol
its hard for me to take my truck anywhere, i dont usually feel comfortable having anyone working on my truck haha
thanks for all the tips guys
where did you get your airtex pump? im thinking of getting a coolant filter as well.
will it be ok to reuse the coolant i just put in 3k miles ago?
post #7 of 12 Old 08-06-2013, 02:12 PM
rascal's Avatar
I am the same way; I do all the work on my truck unless it is paint & body. I let the professionals handle that.
I would re-use that coolant. Especially if you get a coolant filter.
Good luck!
Rascal
rascal is offline
post #8 of 12 Old 08-06-2013, 02:15 PM Thread Starter
Quoted: 247 Post(s)
thanks! ive seen how much nasty stuff those coolant filters pick up.
ya my truck is going to get repainted next spring. tired of all the cracking on the hood lol
post #9 of 12 Old 08-07-2013, 01:40 PM
timmyboy76's Avatar
post #10 of 12 Old 08-07-2013, 03:05 PM Thread Starter
Quoted: 247 Post(s)
i appreciate all the help guys!
luckily i get a discount at the local napa. ill head in there and give the guys the list you provided.
once again, thanks guys.
