Why is my truck shaking at 70 mph? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-04-2013, 01:20 PM Thread Starter
According to specs on the door I should be running 55psi in the front but I'm running 70psi. Could that be my problem?
cory5517 is offline
post #2 of 4 Old 08-04-2013, 02:53 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
No clue as to what kind of truck you have. It could be a few things from suspension geometry, tires, a u-joint, carrier bearing etc. Is it coming from up front, back, dont know? You're going to have to be a little more specific.
I would only gauge what your PSI should be based on your tires. Read the sidewall and adjust accordingly when you have not driven the vehicle and the tires are cold. I generally set mine 5 PSI below the max. Everybody will have different suggestions based upon their driving/towing. Stand by.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 4 Old 08-04-2013, 10:51 PM
Check your tires for tread seperation usually evidenced by a bulge in the tread area. If it's been going on for a while the area will be worn more then the rest of the tire too. Also have your tire balance checked.
Tire cupping caused by alignment issues might be the problem too but will be more of a vibration than shake.
If it's making the steering wheel shake concentrate on the front, if not felt in the wheel, the rear.
ricoyam is offline
post #4 of 4 Old 08-05-2013, 12:42 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
is it only when your giving it gas or all the time? is it in the wheel or the whole truck? worse at different speeds?
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
