Gauge Recommendations - Ford Powerstroke Diesel Forum
View Poll Results: Which Gauge other that Pyro?
Turbo Boost 1 6.25%
Fuel Pressure 5 31.25%
Trans Temp 9 56.25%
Eng Temp 1 6.25%
Voters: 16. You may not vote on this poll
post #1 of 27 Old 08-03-2013, 11:03 AM Thread Starter
I've got an 02 7.3L and was going to add the RiffRaff F650 dash for the upfitter application.
Riffraff Diesel: Riffraff Custom Auto Dash Kit
It comes with 2 spots for extra gauges and wanted help deciding which two to buy.
I was thinking Exhaust Gas for one....but what about the other? What's the weakest link I should be monitoring?
marinepilot81 is offline
post #2 of 27 Old 08-03-2013, 11:08 AM
zdawg8394's Avatar
Boost. Especially since those trucks don't have a boost gauge stock. 7.3 is pretty strong and reliable shouldn't need to many parameters
08 F350 6.4 4x4 Lariat CCSB
-BDS 4 inch radius lift - Fox 2.0 shocks - XD monster 20x10 chrome rims - Toyo open country m/t 37/13.50/r20 - Procomp dual steering stabilizer w/fox stabilizers - 2wd valance - HID heads and fogs - escort 8500 x50 blendmounted - CTS insight with dash pod - interior led conversion
"When you nail the throttle in traffic trying to get around someone chr*st I think GM could have mailed me that 400hp faster then I got it out of the truck."
zdawg8394 is offline
post #3 of 27 Old 08-03-2013, 12:02 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I'd say trans temp if you have an automatic. Way more important than boost (unless your running a modified waste gate, aftermarket injectors). Need more info for a better suggestion!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 27 Old 08-03-2013, 12:07 PM
usnavyad's Avatar
Feedback Score: 3 reviews
Honestly it's hard to pic one pid I'd honestly say run edge cts to monitor all of the above
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #5 of 27 Old 08-03-2013, 12:08 PM
Quoted: 8 Post(s)
7.3 doesn't have all the PIDs as our 6.0...
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 27 Old 08-03-2013, 12:20 PM
usnavyad's Avatar
It still has alot read from obd I can read them from my snap on ethos so a cts will read the same ones so mechanical gauges still a waste IMHO
GPDA's other shawn
usnavyad is offline
post #7 of 27 Old 08-03-2013, 12:26 PM
Term3's Avatar
I have Dakota Digital gauges and my three side pillar gauges can display seven inputs. HPOP and fuel pressure / boost, temperature (ATF) and exhaust temperature / oil pressure and oil temperature. You can choose alarm set points for each input and can display just a single input so that its shown in large digits. I LOVE them and I've had they about eight years so far with zero issues.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #8 of 27 Old 08-03-2013, 12:42 PM
Quoted: 8 Post(s)
Wait... The 7.3 will display fuel pressure, trans temp, and engine oil pressure? Without needing addition sensors?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 27 Old 08-03-2013, 12:45 PM
usnavyad's Avatar
I'm not 100% on what ones it's been a year since I scanned my own 7.3l but the PCM will put out more pids then the ones u are going to mechanically Install plus the gauges just look tacky to me
GPDA's other shawn
usnavyad is offline
post #10 of 27 Old 08-03-2013, 12:47 PM
jesilvas's Avatar
Quoted: 2 Post(s)
I run boost, EGT, ECT, and trans. Honestly, the boost is just for fun and about useless. Trans and EGT are most important. ECT is really useless to me after doing it.
4R100, 2wd
330,000 + miles
jesilvas is offline
