Power mirror question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-03-2013, 09:23 AM Thread Starter
Is there a way to know if the power mirrors have the round or square electric plug without having to take the door panel off?
Thanks!
andyt50 is offline
post #2 of 11 Old 08-03-2013, 09:46 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Someone will correct me if I'm wrong... But the 03-07 mirrors have the grey rectangle plug and the 99-02 mirrors have the white round plugs. Not sure on the 08-up mirrors... More info need on what style of mirror your talking about.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 11 Old 08-03-2013, 09:57 AM
Powerstroke_21's Avatar
I bought "supposedly" 02 tow mirrors off a wrecked truck and they have the gray rectangle plug. But they could be 03 except they don't have the turn signals in them
Sent from AutoGuide.com App
Jarrette
1999 F350 ecsb 4x4 130k miles.
Mbrp 5" exhaust
TS 6 pos chip with Gearhead tunes
Auto Meter CS Series gauges (boost, pyro, trans temp)
S&B Intake
Aftermarket wastegate controller
Mods to come:
Crank case vent
Hutch and harpoon mod (if not already done)
1997 F250 rclb 4x4 gasser
Going to do a 12v swap in it tho
Powerstroke_21 is offline
post #4 of 11 Old 08-03-2013, 10:04 AM
Quoted: 8 Post(s)
Seems like that's an 03 mirror plug.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 11 Old 08-03-2013, 11:37 AM
The wires are the same color. Realy easy to cut them and connect the new mirror
http://www.eurekaboy.com/f250/newmirrors2.htm
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
post #6 of 11 Old 08-03-2013, 12:15 PM Thread Starter
These are the ones I'm looking at. Even though the ad says for a wide variety of years, I've soeen some with a rectangular plur and other with the round. I have a 99 F250 Super Duty 7.3.
http://www.ebay.com/itm/Ford-Super-D...f1ee51&vxp=mtr
thanks!
andyt50 is offline
post #7 of 11 Old 08-05-2013, 07:55 AM
I just got mine. Everyone said not to buy the Chinese ones on ebay
I went to all the junkyards and found the passenger one for 50 and the driver one was an used OEM from eBay for 66
Keep looking for OEM the aftermarket ones vibrate
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
post #8 of 11 Old 08-05-2013, 08:49 AM
Yeah same here, the guy said they were 02 mirrors so I didn't think to look at the plug on my truck to make sure they would work because I wasn't aware that they changed the plug on them
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #9 of 11 Old 08-05-2013, 01:04 PM
Quoted: 8 Post(s)
Plugs changed in the door with different model years... Not options available for the mirrors. Hope that makes sense.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #10 of 11 Old 08-05-2013, 01:26 PM
Snake's Avatar
Quoted: 47 Post(s)
I picked up a set of 08 style tow mirrors from 1A Auto Parts and they vibrate less than my OEM's. And they sell the plugs / adapters if needed. They're also a site sponsor. I'd encourage you to check them out before you make a choice.
tmarchand@1aautoparts.com
or
www.1aautoparts.com
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
