Boost gauge help - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-02-2013, 11:47 AM Thread Starter
Boost gauge help
Ok I bought Hey boost gauge but I don't know the drillbit sizes and tap size to thread the fitting in help please 2000 7.3 f350
power00 is offline
post #2 of 9 Old 08-02-2013, 11:55 AM
rascal's Avatar
I could be wrong but most boost gauges (electronic) use a 1/8 NPT. Use a 11/32 drill bit.
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #3 of 9 Old 08-02-2013, 11:58 AM
goats's Avatar
Quoted: 2 Post(s)
Just make a "T" fitting in the map line ,so no drilling needed
goats is offline
post #4 of 9 Old 08-02-2013, 11:58 AM
Quoted: 31 Post(s)
Did you buy a boost gauge or an EGT gauge?
Boost gauge most people either buy the intake heater plug which has a port for your boost gauge or they put a T fitting into their MAP sensor line and connect the gauge to that.
If your talking about an EGT gauge then it should be put into the driver side manifold and a 1/8" NPT tap is what you will want unless yours has a 1/4" NPT end on it then you would use that. When you buy the tap some come with the right bit, some dont so you can just ask the parts store what one to use with it or google it, i cant remember off the top of my head.
CarportMechanic is offline
post #5 of 9 Old 08-02-2013, 12:00 PM
rascal's Avatar
I was thinking of an EGT probe! See, I said I could be wrong!
For my boost gauge I am using the plug I put in when I did my IAH delete.
Rascal
rascal is offline
post #6 of 9 Old 08-02-2013, 12:01 PM Thread Starter
I bought a boost gauge because I have a chip tuner and I wanted to monitor boost
power00 is offline
post #7 of 9 Old 08-02-2013, 02:30 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
go to riffraffdiesel and buy the AIH delete that is tapped for a boost gauge.
looks clean and its a good piece.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #8 of 9 Old 08-02-2013, 08:19 PM
Eco Taxi's Avatar
X2 I like mine alot
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #9 of 9 Old 08-05-2013, 03:54 AM
rocktamer's Avatar
I put a tee inline with the tubing going to the trucks boost sensor (proper name is escaping me). No drilling needed which is a plus cause the Y pipe is like $100 used and tough to track down.
1999 F250 XLT 4X4
rocktamer is offline
