converting electric shift T Case to manual? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-02-2013, 06:41 AM Thread Starter
A month or so back I was on my way to SD for a prarie dog shoot when an incident cause the front drive shaft to split the slip yolk fall out hit the pavement and peel the front output side right off of my TCase. Big ugly mess on the side of I-80.....
Well I bought a TCase and put it in, but there is no power(?) to the switch. My hope is that since the new plug had different colored wires than the original harness we crossed a wire up somewhere. My fear is that when the casing was ripped apart and spit out the back of the truck, one of the wires on up the harness got broke.
Now on to my question. I know on most EShift TCases you can manually shift them with the motor off of the case, can I just cut the hole in my floor out and convert my current TCase to shift manually?
Jim
2000 7.3l 4x4 6sp
DIY intake
4" exhaust
6pos by Dyno Proven
Wicked wheel
160cc
Honey Badger jr
custom clutch
Auto Meter Z series gauges
jimmyp is offline
post #2 of 4 Old 08-02-2013, 07:05 AM
chrispaine's Avatar
Well I can't help you with your questions I would like to know also. My last truck had the ESOF 4x4 and it was nothing but problems! That was one reason why I sold it and the next truck had the floor shifted 4x4. Good luck!
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #3 of 4 Old 08-02-2013, 01:09 PM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
Do a search in this section. A member did this conversion. I think it would be cheaper to just get a manual case from a wrecked truck
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #4 of 4 Old 08-02-2013, 03:13 PM
JSchuricht's Avatar
Your best off just swapping the transfer case but you can convert it with limited functionality. The manual stuff is not a direct bolt on for an electric case and the sensor is different. You would also not have a neutral position like you would on a manual case.
JSchuricht is online now
