BAD MOTOR? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-01-2013, 09:06 PM Thread Starter
BAD MOTOR?
can someone please tell me what yr blocks and heads are interchangeable on the 7.3? I have a 2001 and the dealer is saying I have low compression in cylinder 8 and 5, I find it hard to believe its the rings since I only have 250000 miles on it. maybe valves? O rings on the injectors? If it is the rings, cant I just drop the pan and pull the head and replace the rings in those cylinders? this is my first diesel but I have built several motors. any help is greatly appreiated.
FordFreak801 is offline
post #2 of 4 Old 08-01-2013, 09:10 PM Thread Starter
three weeks the dealer had my truck, and 800.00 later they say I need a motor and turbo for 10,000.00
post #3 of 4 Old 08-01-2013, 10:45 PM
timmyboy76's Avatar
why was it at the dealer in the first place? Damn, $800 buks, and you were only 300 buks away from getting a rebuild kit.
Riffraff Diesel: Ford Overhaul Kit
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 4 Old 08-01-2013, 11:34 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
I wouldn't trust a stealership for anything. I'd take it to a reputable diesel shop in the area if there's one available. They're generally not out to make a quick buck but want repeat customers. With that comes better service.
O-rings seem to be a common and quick fix. I'd pull the injectors out and take a look.
Reman motors can be had for half of their quoted price...
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
