fuel system upgrades - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-01-2013, 05:17 PM Thread Starter
bulldogsf350's Avatar
alright guys I need some help. I am getting ready to upgrade my HPOP. While I'm in there I was going to do a DIY RR, and the Hutch mod. So here are my questions, 1) I have seen plans on building a RR kit but I can't find them anymore, does anyone have a link to one? 2) I know I will need to add fuel filters at the pump. I plan on adding a water sep before the fuel pump and then the filter after the pump. does anyone have plans for the filters, I've seen second factory pumps added, Do I really need to add a second pump? and I've seen ball valves before and after the filter assembly, Do I need these? And should I increase fuel line size?
HPOP is going to be the T500,
eventual upgrades will be stage 1's, 38r, WW2
I already have 4" Diamond Eye Turbo Back Exhaust, 6637, Gauges, F5 Chip
Thanks guys
03, F350, 7.3, CC, Dually, 2WD
bulldogsf350 is offline
post #2 of 10 Old 08-01-2013, 09:48 PM
timmyboy76's Avatar
theres r.r kits or diy also. You can r.r. the fuel and keep the fuel bowl for filtering....hutch mod is nothing more then a 33007 filter before pump and keep the fuel bowl filter. Or install a spin on with base from fleetfilter..(its what i did). The factory fuel pump is all thats needed.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 10 Old 08-14-2013, 02:44 PM
Timmy, where did you put your fleetfilter?? Pics? Thx
mram10 is offline
post #4 of 10 Old 08-14-2013, 04:42 PM
Not another PowerPoint
Unrated Diesel's Avatar
For the price of an Airdog you can build your own system with an A1000 and including the RR syetem. There's many ways to do a fuel system. Not to hate on airdogs they have they pros and cons I ran into many problems with mine.
UPCOUNTRYDIESEL
Had H&S wasnt that great so dont tell me there good
2012 F350 6.7L Spartan Tuner ETC.
2008.5 F350 6.4L DWR Spartan Tuner ETC..
1999.5 F250 7.3L DP Tuner... Blah Blah RACETRUCK
Unrated Diesel is offline
post #5 of 10 Old 08-15-2013, 03:14 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
With RR systems, options are all over the map. For smaller injectors I would just do a hutch and FRX and keep the factory fuel bowl. Just keep it simple IMHO.
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #6 of 10 Old 08-16-2013, 06:06 AM
timmyboy76's Avatar
installed pre-pump
post #7 of 10 Old 08-17-2013, 01:08 AM
Yeah i was going to same the same thing lol
UPCOUNTRYDIESEL
post #8 of 10 Old 01-05-2014, 06:42 AM Thread Starter
ok guys i finally got all of the parts for my RR system w/Fuel bowl delete, replacement filters and in tank mods. So here are my questions, I have a fuel/water seperator and a 5 micron filter. I have seen some people put either 1 or 2 fuel pumps between the 2 filters while still keeping the factory pump. I know i will need atleast 1 pump in between the filters but do i need 2. also what about the factory pump, will i still need it if i do the 2 pumps in between the filters.
i'm looking at some stage 2's, 38R w/WW2, T500. I already have intake, exhaust and a chip.
Thanks again guys for all of your knowlwdge
post #9 of 10 Old 01-05-2014, 09:30 AM
Joel's Avatar
Quoted: 10 Post(s)
I would buy a fuel pressure gauge and do the hutch mod for now.
If you insist on spending a little more, do the FRx as well.
There is no point on spending $500 on a fuel system if you have no idea what it's doing at full throttle.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #10 of 10 Old 02-03-2014, 08:39 PM
hardtail70's Avatar
Here is a link to the basic DIY RR and fuel bowl delete I want to doo this spring Home Brew Fuel System for my Early 99 Powerstroke Turbo Diesel
I am going to use Summit Racing brand stuff instead of areoquip. Look at Parker's Racor line for filters and etc. I recommend a fuel heater if you live up north. I have been having freezing filters with this 20 below temps here. I did the hutch mod and used napa filters and filter mount. Racor sells a heated separator / filter with a water in fuel sensor which is nice to remind you to drain the water especially if you delete the factory 7.3 filter assy. I had to replace one on my old OBS and it cost over $500. I wish I was on this site back than. oh well hindsight is 20/20. racor also has an all in one filter pump setup. you only need one fuel pump in my opinion.
Between the hutch mod and a RR you will have a much smoother running powerstroke. getting rid of the fuel bowl can eliminate expensive repairs if it leaks and spin on filters are cheaper than our factory ford ones.
2000 F350 XLT 7.3 Powerstroke Diesel, 4x4 longbed, extended cab, auto trans, 3:73 gears, AEM intake, summit racing 5" turbo back w/4" downpipe exhaust, Custom 8' Steel Flatbed w/Omaha sissor lift, Stahl Contractors cap, Goodyear Wrangler Duratrac LT285-75-16 E, Black alum rims, 08 Power everything lighted heated tow mirrors, 08 door panels, 08 console, Hutch and Harpoon mods and the rest is stock.
Next project will be RR and bowl delete fuel mods but deciding which route to go.
hardtail70 is offline
