Installed WW2 and need feedback - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-31-2013, 04:50 PM Thread Starter
Silver200273L's Avatar
So finally had the wicked wheel 2 installed and took turbo out and put all new o-rings. No play in ball bearing. Everything looks good. Put it back together and installed new Riffraff intercooler boots while I'm at it. Well been driving for almost a week. Well I fill up the tank and it been 5 days and I'm almost half tank. I swear I don't drive hard or anything. I drive 50 miles to work and highway speed. What would cause bad fuel mileage? I checked for fuel leak and everything looks dry. Also my egt is really high! Before it was way lower before install ww2. It like 500-1,000 degree more after ww2 installed. Anybody got idea why?
DP Tuner
Dieselsite Wicked Wheel II
5" Straight Pipe
6637 DIY Intake
Riffraff Intercooler Boots
Riffraff CCV
Harley Davidson Headlights Conversion
05-07 Grille
2.5 Leveling Kit
33" BFGoodrich All Terrain
LED tail lights
Billet Grille
Line of Fire
Silver200273L is offline
post #2 of 5 Old 07-31-2013, 11:23 PM
layson's Avatar
Quoted: 83 Post(s)
You have either a boost leak (leaking boot, missing the big o'ring on the turbo). Or an up-pipe leak, maybe you didn't get the back of the turbo in correctly on the up-pipes.
Did you get the little exhaust back pressure valve hooked on the turbo. It comes out of the turbo pedestal and hooks on the bottom of the exhaust housing.
Check all these out, if you still have the issue I would call up Clay at Riffraff.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 5 Old 08-01-2013, 02:21 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
layson pretty much covered everything.
i personally almost forgot to hook the stupid actuator back up lol so its possible.
you definately have a leak somewhere.
whats your boost numbers at WOT?
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #4 of 5 Old 08-03-2013, 12:47 AM
J'sF-250's Avatar
I put a ww2 from riffraff in my 02 and I already had the new boots on before the install... I noticed a little bit higher of EGT but only 200 higher? Compressor surge is gone after install... I'd check the stuff they said tho and maybe just give everything a once over and tighten again
Sent from AutoGuide.com App
02 F-250
4inch procomp suspension lift
35inch Nitto trail grappler MT's
Black sport grill
18 inch rims
Warn locking hubs
Gen2 RiffRaff wicked wheel
Straight pipe
6.0 Tranny cooler
Maghytech deep Tranny pan
6637 Intake mod/RiffRaff pre filter
RiffRaff inter cooler boots
CCV mod
Boost/Pyro/Trany/Volts on pillar
DP-Tuner F5- high idle, 60 tow, 80 eco
J'sF-250 is offline
post #5 of 5 Old 08-03-2013, 08:04 AM Thread Starter
Ok thank you for all the replies. Actually I didn't install thw wheel. I had flexplate went out and got it tow in the doesel shop and also had them install the wheel at the same time and new o-rings. I put new boots on and the boost psi at WOT not a whole lot. I haven't really putting that hard while WOT. I would say 25psi maybe. Anybody got picture how their tubes connect to the turbo to read the boost? My lines for the boost gauge goes to the hose that go to MAP. Didn't know if that's right way?
DP Tuner
5" Straight Pipe
6637 DIY Intake
Riffraff CCV
05-07 Grille
2.5 Leveling Kit
LED tail lights
Billet Grille
Line of Fire
