how often do you change? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 15 Old 07-31-2013, 06:03 AM Thread Starter
Quoted: 16 Post(s)
Feedback Score: 3 reviews
I change oil and filter every 5k
I change air filter every 10k
I have been changing fuel filter every 5k but I just did the hutch mod. How often does everybody go on both fuel filters?
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #2 of 15 Old 07-31-2013, 07:25 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
Are you running a 6637 and changing it every 10k? And a fuel filter every 5k? That is a bit overkill.
Oil and filter: 5000-7500
Fuel filter: 15,000
ATF: 30,000
Power steering ATF: annually
Brake fluid: every two years
Diffs: front 50k, rear changed 50k miles ago... probably won't touch it for another 50k
Coolant: However many years it says on the bottle or how the test strips are doing.
6637 air filter: 50k
What filter did you end up using on the hutch mod?
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #3 of 15 Old 07-31-2013, 07:34 AM Thread Starter
Quoted: 16 Post(s)
Baldwin Bf1212
post #4 of 15 Old 07-31-2013, 07:43 AM
Quoted: 17 Post(s)
Baldwin Bf1212
Not the exact same but similar. I ran this set up on my old dodge:
Cat fuel filter set up - Dodge Cummins Diesel Forum
Would run 45k intervals and the filters still had life in them, fuel pressure never budged.
If you want to be conservative you should able to run 20k intervals no problem. Do you have a fuel pressure gauge? If not I would get one and use it as a judge when to change the filters.
post #5 of 15 Old 07-31-2013, 05:52 PM
hansel's Avatar
Quoted: 97 Post(s)
Oil @ 4,000 miles
Fuel filter @ 10,000 miles
Air filter @ 10,000 miles (cleaning)
Tranny @ flush 16,000 miles
Rear Gear @ 30,000 miles
Coolant @ 60,000 miles + additive @ 15,000 miles
I know these mileages might seem low, but I'm all about taking care of all the fluids
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #6 of 15 Old 07-31-2013, 06:13 PM
ScottyP5947's Avatar
5k oil and filter
7.5k fuel filter
30k trans fluid flush
50k axles
air filter - yearly (10k or so)
I am about to do the hutch mod, and plan to change the factory filter at the same time. I suppose I'll be good for a long time on the factory filter, at least 2x as long as the new baldwin. I love that they are cheap and will be easy to replace.
Scott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit
Zoodad
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Caterpillar ELC coolant
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife)
1995 Ford Mustang 3.8 (
2012 Dodge CCSB 2500 w/Hemi
ScottyP5947 is offline
post #7 of 15 Old 09-14-2014, 07:37 AM
7.3powerstroke99's Avatar
Know this is a old thread but curious what miles everyone has on there trucks that change at these intervals
7.3powerstroke99 is offline
post #8 of 15 Old 09-14-2014, 06:42 PM
hansel's Avatar
Quoted: 97 Post(s)
226K on mine right now, but this is my second 7.3L my first one went 257,998 miles when she got wrecked
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #9 of 15 Old 09-14-2014, 09:55 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
oil is pretty standard at 5k miles. new filter of course. you can have an analysis done to see if you can go longer.
air filter-depends on what filter you run and your driving conditions (dusty, highway etc etc)
fuel filter 10k
trans-30k
axles 50-60k
transfer case every 50k
power steering-every 2 years.
coolant-every 70-100k miles.
brake fluid-just check and see how much water has gotten in and how dirty the fluid is. its cheap to do.
john galt likes this.
blue99stroker is offline
post #10 of 15 Old 09-14-2014, 10:31 PM
john galt's Avatar
Quoted: 1227 Post(s)
So far I have been pretty much a
5k oil
10k fuel
and minder on the air filter guy.
just turned 147k
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
