How to move bed when off truck? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-29-2013, 03:25 PM Thread Starter
chrispaine's Avatar
I am going to replace the supports (rusted) under the bed of the truck and cut out the inner metal fender where the rust starts on the wheel wells of the bed. Going to have to do some sandblasting and other messy work and would like to wheel it out of the garage when it gets nasty.
Any good ideas other then 4 dudes to move it in and out of the garage when it is flipped over ?
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #2 of 7 Old 07-29-2013, 04:03 PM
Zaairman's Avatar
Quoted: 12 Post(s)
Go get a couple of cheap 4 wheel movers dollies from Harbor Freight.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 7 Old 07-29-2013, 04:56 PM Thread Starter
chrispaine's Avatar
Good idea, much cheaper then car dollies that I was thinking of!!
On the way--
post #4 of 7 Old 07-31-2013, 05:36 AM
Mitch
thebierguy's Avatar
Quoted: 89 Post(s)
Is it hard to pull the bed off??
Mitch
2006 Ford F-350 6.0 Crew Cab Lariat Short Box./4" exhaust/SCT X4 7015 (White Noise)/Autometer Boost and Fuel Pressure(Strictly Adapter)/Edge Insight CTS2/FICM Repair.com Complete Wire Kit/08+ Rear Differential Cover/B&W Goosneck hitch/Sinister Coolant Filter/High Idle/Blue Spring/Purchased 2/28/2014
2002 Ford F-350 7.3 Crew Cab Lariat Short Box, SOLD 2/24/2014
thebierguy is offline
post #5 of 7 Old 07-31-2013, 08:54 AM
Quoted: 17 Post(s)
Use an engine lift to pull it off if you don't have enough people pull it off. I'd say maybe even ratchet straps if you had a way to rig overhead.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #6 of 7 Old 07-31-2013, 04:51 PM Thread Starter
chrispaine's Avatar
I plan on lifting it off with 4 people, should work?!
On the way--
post #7 of 7 Old 07-31-2013, 06:06 PM
Zaairman's Avatar
Quoted: 12 Post(s)
Four people and two 2x4x8s and it will be easy.
Zach
SLAPS Member #153
Zaairman is offline
