Extended drivelines - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-27-2013, 10:04 PM Thread Starter
Extended drivelines
I have an 8" lift on my truck and everywhere i read for 8" lifts they say that you should change out your drivelines or extend them?
I know that my inner spline on the front driveline is barely in there...not enough for me to feel comfortable using my 4 wheel drive for anything serious.
Does anyone know where to go to get new or extended drivelines for the purpose of having an 8" lift or higher?
I guess more specifically, i want to know if there are any companies that sell these as apposed to going down and having a driveline shop custom make one.
any information will be helpful. thank you in advance
zac93218 is offline
post #2 of 8 Old 07-28-2013, 01:25 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Any custom driveshaft shop will be able to easily lengthen both front and rear shafts, way cheaper than getting any full aftermarket shafts.
As long as everything is in good shape, you'll probably spend 200$ or less per shaft to get them cut, a new tube, and re welded.
I had a rear shaft made from scratch, new everything cv head, u joints, the slip, and the tube Then the front shaft lengthened with all new joints.
All spicer stuff total was 1100$ for both.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 8 Old 07-28-2013, 07:32 PM Thread Starter
should i also look in to "shimming"? the rear driveline? Not sure if that is the correct term for what im asking...i have heard of the kit before but cant remember the name..basically where the first part of the rear driveline connects to the second part of the driveline, they say that mount should be lowered when you have 8" or more of lift so that it puts less stress on the driveline and creates less wear and tear...does anybody know what "kit" im talking about and where to find them?
zac93218 is offline
post #4 of 8 Old 07-28-2013, 07:42 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Just clock your transfer case, its what i did and it put my pinion angle and spline engagement back in check
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 8 Old 07-28-2013, 07:51 PM
schlutzer's Avatar
Quoted: 18 Post(s)
OP I think you are talking about a carrier bearing shim kit. If so my answer is, that depends.
Single cabs, and extended cab SHORT box trucks have a 1 piece driveshaft so no that's not needed.
If your truck has a 2 piece shaft then yes a carrier shim kit is needed for that much lift.
Ramm, if I understand right you are talking about roatating the Tcase right? That will only affect that front shaft won't it? but hell I wish I had thought of that before I got a custom shaft made for mine.
post #6 of 8 Old 07-28-2013, 08:25 PM
Chapter Director
Quoted: 5 Post(s)
Yes sir, it actually helps both, you buy an adapter plate that pushes the t-case out by whatever the thickness of the plate is therefore allowing more spline engagement on the rear shaft and then turning the t-case changes the angle of the front shaft and also pushing it forward allowing more spline engagement
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 8 Old 07-28-2013, 11:44 PM
schlutzer's Avatar
Quoted: 18 Post(s)
That's interesting I didn't know anybody actually did that.
post #8 of 8 Old 07-29-2013, 07:43 AM
Quoted: 761 Post(s)
You can "index" your factory transfer case without a plate but it will be too much for only an 8" lift.
http://www.pmfsuspension.com/NP-2712...Ring_p_31.html
Corey@CNCFAB is offline
