Optilube xpd - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-26-2013, 05:49 PM Thread Starter
jvanwalsen's Avatar
Optilube xpd
Ok guys I figured this is the best addative to use just not sure which one to use. General,summer or winter adative. They all look the same except maybe double them for winter.
jvanwalsen is offline
post #2 of 11 Old 07-26-2013, 07:08 PM
hansel's Avatar
Quoted: 99 Post(s)
I've used the XPD, but the summer blend does not require as much per tank making it less money. It doesn't lubricate like the XPD but it's darn near the same. I like the 1oz treats 10 gallons, so for me it's only 3oz verse the XPD being 8oz roughly.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #3 of 11 Old 07-28-2013, 04:23 AM
My personal favorite. dfi-summer+
Smarty is offline
post #4 of 11 Old 07-28-2013, 07:02 AM
Quoted: 3 Post(s)
2 stroke ashless mixed with dieselkleen.. cheapest and can be found locally.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #5 of 11 Old 07-28-2013, 07:09 AM
Cheapest? No. Local? Sure, but how hard is it to order a 1 gallon jug and have it for 1-2 years?
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
http://www.dieselplace.com/forum/76-...y-results.html
Smarty is offline
post #6 of 11 Old 07-28-2013, 08:01 AM
Quoted: 169 Post(s)
Feedback Score: 3 reviews
So I don't have to type it all again -> Fuel Additive Pricing???
Originally Posted by NoRalPh View Post
So, 2-stroke is the EASIEST. Does the poorest job, and does the least for you (no additional benefits other than lubrication). Basically, it's for the cheap & lazy (OH! THAT'S gonna piss some people off - huh?)
From there, is it really more of a Bang-4-Buck thing than what's gonna be Best for your engine? really??? I mean, and I've never done this because I'm not sure I want to know,,,, have you ever added-up the yearly cost-of-fuel? I bet it's a scary number! Then what percentage of that does the Additive raise it (you know, $3.50 in a $150 fill-up?) Then, what's the cost difference between 2-stroke and a proper additive? How much could the savings/yr as a percentage of fuel cost/yr actually be? And you're losing So Much because you're Not getting improved anti-gel, cetane, or a demulsifier in an additive that's meant to be put in an Outboard Motor for the rings & needle brgs.
I understand the difference between running through WW and taking a $20 bill out of your pocket to grab some 2-stroke and shelling out over $100 all-at-once to purchase 3gal of Opti-Lube. I really do,,, but there are somethings that the easy & convenient just don't exist for and it's time to make the harder & inconvenient choice to do what's in the best interest of what it is you're after...
NoRalPh is offline
post #7 of 11 Old 07-28-2013, 08:06 AM
So I don't have to type it all again -> http://www.powerstroke.org/forum/99-...e-pricing.html
Copy so I to can paste this for future needs!
Smarty is offline
post #8 of 11 Old 07-28-2013, 12:42 PM Thread Starter
jvanwalsen's Avatar
Ordered a gallon of the summer blend. It will put my mind at ease knowing I am doing all I can for the longevity of this truck.
post #9 of 11 Old 08-14-2013, 02:05 PM Thread Starter
jvanwalsen's Avatar
So I have used the summer blend opti lube twice now. Seems like it starts easier, don't know about quiter though
post #10 of 11 Old 08-15-2013, 05:24 AM
rascal's Avatar
XPD for my 2000
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
