7.3 stalls when it rains. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-26-2013, 11:10 AM Thread Starter
My 2003 Excursion with the 7.3 will stall when motor comes close to idle like when coming to intersection or in parking lot. Also will hesitate for a second when going at highway speed. It only happens when it is wet out. Could this be some sort of ground or connection to pump or injectors?
mike70gtx is offline
post #2 of 10 Old 07-26-2013, 11:17 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I would check your CPS wiring it may be frayed and shorting out when it rains
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 10 Old 07-26-2013, 11:23 AM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
What brand cps are you running? Some brands are known to do this when your wipers are on.
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #4 of 10 Old 07-26-2013, 11:25 AM Thread Starter
What is cps and where? I'm assuming something computer. I do have a dp tuner on it.
post #5 of 10 Old 07-26-2013, 11:29 AM
Chapter Director
Quoted: 5 Post(s)
97 03 Ford 7 3L Powerstroke Diesel Cam Position Sensor | eBay
Its on the front of the engine. Its kinda hard to see from the top you gotta get underneath and look at the crankshaft its on the left side near the top. Very common thing to go bad on the 7.3 to the point people carry an extra in the glovebox to change on the side of the road like i had to do the other day
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 10 Old 07-26-2013, 11:41 AM
Quoted: 157 Post(s)
See what happens if you turn the wipers on when it's dry....
Stumbles when it rains??
NoRalPh is offline
post #7 of 10 Old 07-26-2013, 01:18 PM Thread Starter
Just drove it and wipers don't seem to effect it. Haven't had time to check cps
post #8 of 10 Old 07-28-2013, 06:22 PM Thread Starter
i did see where the 2003 excursion has a recall so I scheduled this week to get the new cps and something with the cruise control
post #9 of 10 Old 07-31-2013, 04:00 PM Thread Starter
Did the recall and got (assuming) new cps and fixed recall issue with cruise. Put the wipers on intermittent and didn't die. Just need to wait for some rain to see if that fixed it.
post #10 of 10 Old 07-31-2013, 05:56 PM
hansel's Avatar
Quoted: 97 Post(s)
I had the cheap parts store CPS, and this would happen when the wipers where on, I went and got Ford CPS and have not had an issue's.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
