Pillar guge install, now battery light is on - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-26-2013, 09:02 AM Thread Starter
LOTTS73's Avatar
I connected all of my illumination wiring to the "headlight on" hot wire at the headlight harness. The "key on" hot I used a random wire under the dash that I found with the test light. Do you guys think that is the issue? I think I may have tied into the wire that throws the dummy light on? I think it is the trans. temp gauge that needed the "key on" hot wire..
01 F-350 7.3 Auto/6637 mod/Muffler delete/Pillar gauges
LOTTS73 is offline
post #2 of 9 Old 07-26-2013, 09:24 AM
hansel's Avatar
Quoted: 97 Post(s)
This the link too Diesel manor's instructions, I follow it too a "T" everything went perfect.
3-Gauge Install Pictures
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #3 of 9 Old 07-26-2013, 09:29 AM Thread Starter
LOTTS73's Avatar
I used diesel manor for my install, I could not remember which wire to use for the "key on hot" so I just started checking wires with the test light. I will disconnect that one and see if the battery light goes away..
LOTTS73 is offline
post #4 of 9 Old 07-26-2013, 09:37 AM
hansel's Avatar
Quoted: 97 Post(s)
Find the light blue with red trace, that's the one your looking for.
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #5 of 9 Old 07-26-2013, 09:39 AM
hansel's Avatar
Quoted: 97 Post(s)
Here is the hot connection under the steering wheel
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #6 of 9 Old 07-29-2013, 05:12 AM Thread Starter
LOTTS73's Avatar
it was the stupid alternator from Oreilly's I just put on 3 months ago. The bearings were going bad. This is the 2nd one I have had to replace due to bad bearings. Thank God for a warranty!
LOTTS73 is offline
post #7 of 9 Old 07-29-2013, 05:28 AM
hansel's Avatar
Quoted: 97 Post(s)
What where the odds that as soon as you hook up gauges the alternator blows up years ago I thought the bearing had gone in my alternator so I replaced it with a unit from Ford, ended up being the belt making the noise
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #8 of 9 Old 07-29-2013, 05:35 AM Thread Starter
LOTTS73's Avatar
Guy at counter- I wonder what is screwing these up?
Me-Maybe change rebuilders..
Guy at counter- Why?
Me-
LOTTS73 is offline
post #9 of 9 Old 07-29-2013, 01:11 PM
hansel's Avatar
Quoted: 97 Post(s)
Me-
Sounds like is "clueless"
I would have told him it's that awesome 7.3L we own
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
