2000 7.3 idleing fine then started loping no throttle response died+ - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-25-2013, 04:04 PM Thread Starter
truck was idleing in driveway started to lope pressed gas pedal nothing no response then died went to re start truck would spudder an not start same thing the next day any ideas on what to check first fuel pump is running
d.mclane is offline
post #2 of 3 Old 07-25-2013, 04:19 PM
KingStroker70's Avatar
Try unplugging the icp sensor on the driver side oil rail that should make the ipr go into a default position and if it fires up that icp sensor is the issue. checking fuel pressure just in case couldnt hurt.
KingStroker70 is offline
post #3 of 3 Old 07-26-2013, 04:00 AM Thread Starter
thank you so much will try this morning really love my truck but so freaked when something goes wrong will let you know ty again
d.mclane is offline
