Re: 180,000 miles trans, tow with tune or stock? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-25-2013, 02:24 PM Thread Starter
chrispaine's Avatar
I have around 180k on my stock trans and I and going to tow a small 16' fishing boat from Michigan to Florida. Should I tow with a tow tune with they PHP Hydra or stock tune? Obviously with this kind of mileage I am looking longevity!
Thanks.
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #2 of 7 Old 07-25-2013, 03:55 PM
Quoted: 27 Post(s)
Use your PHP tow tune. It is programmed to adjust shift points on your tranny which help it while towing. You fishing bout aint that heavy tho so i think you will be just fine either way.
As long as your tranny shifts normal now you will be good.
CarportMechanic is offline
post #3 of 7 Old 07-25-2013, 04:41 PM Thread Starter
chrispaine's Avatar
yeah tranny shifts good now..
On the way--
post #4 of 7 Old 07-25-2013, 04:43 PM
timmyboy76's Avatar
its 16ft!!! you'll not even know its back there.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 7 Old 07-25-2013, 05:20 PM Thread Starter
chrispaine's Avatar
Ha, very true! Just worried about my old trans!
On the way--
post #6 of 7 Old 07-25-2013, 05:55 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 16 Post(s)
I tow around my 16ft on the stock tune and I forget it's even back there. If you're stop/go, sure. Whatever floats yer boat () With traveling that distance on highway miles, I'd play it safe and stay stock.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #7 of 7 Old 07-25-2013, 06:17 PM
hansel's Avatar
Quoted: 94 Post(s)
I would tow it in a tune, the way Jay explained it too me is that if I'm going to travel on the highway for a long distance, place the truck in one of the 80 or 100HP performance tune because the truck has more power makes it easier to travel down the road making it more fuel efficent. I really don't understand the logic behind that, but I've been using the 100HP performance around town, and I believe my fuel mileage is actually better than it was stock, I will know when I fill up exactly what was the mileage.
But like others have said a 16ft boat your not going to really know it's back there.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
