College - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-24-2013, 08:41 PM Thread Starter
College
I will be heading to college this fall and being from wisconsin my truck will need to be plugged in during the school year. I will be living on campus and don't think ill have access to an outlet. Does anyone have any ideas on what I can do or is my only alternative buying a winter beater to avoid beating the piss out of my truck starting it up in the morning? Any advice would be awesome! Thanks
bigstank is offline
post #2 of 9 Old 07-25-2013, 04:21 AM
Zaairman's Avatar
Quoted: 12 Post(s)
5w40 oil, new glow plugs and GPR, and make sure your injectors are in good shape and you'll be good to go.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 9 Old 07-25-2013, 04:57 AM
get a very long extension cord. lol
zillafreak is offline
post #4 of 9 Old 07-25-2013, 05:46 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
10w-30 (CJ-4) or 5w40 oil, at very least ohm your GPs to make sure they are up to task, a stancor relay and I found some benefit from an HPX. As mentioned above make sure your injectors are all working properly as well. With all that you will have no problem starting below zero.
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #5 of 9 Old 07-25-2013, 12:02 PM
jacobm24's Avatar
Our campus has a few plugs for electric car charging...try finding one of those if possible. I have always wanted to do it (just to do it..) but it never gets below 20 here
2000 f250 7.3 w/ 103k miles
4" MBRP turbo back exhaust
DIY Intake with AFE big boost filter
Autometer Cobalt gauges (trans, boost,pyro)
PHP Phoenix stock, 40ht,80dd,120race
Wicked Wheel
Harpoon Mod
203* thermostat
Dieselsite coolant filter
Dieselsite IC Boots
Fightin' Texas Aggie Class of 2013!
Petroleum Engineering
jacobm24 is offline
post #6 of 9 Old 07-25-2013, 01:34 PM
Mitch
thebierguy's Avatar
Quoted: 85 Post(s)
second this - Rotella T6 5w-40 is great. Also the stancor GPR really works well!
Mitch
2006 Ford F-350 6.0 Crew Cab Lariat Short Box./4" exhaust/SCT X4 7015 (White Noise)/Autometer Boost and Fuel Pressure(Strictly Adapter)/Edge Insight CTS2/FICM Repair.com Complete Wire Kit/08+ Rear Differential Cover/B&W Goosneck hitch/Sinister Coolant Filter/High Idle/Blue Spring/Purchased 2/28/2014
2002 Ford F-350 7.3 Crew Cab Lariat Short Box, SOLD 2/24/2014
thebierguy is offline
post #7 of 9 Old 07-26-2013, 11:33 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Make friends with the matinence department they may let you plug it in at their shop. If not carry alot of WD40 to start it, had to use that after my RA confinscated my power cord last winter. A small generator in your bed you can start up a few hours before you need to drive. Or a propane tank with the flame thrower attachment you can aim at the oil pan works too might get some funny looks though from the college police on that lol. Also if you have an oil change between now and the cold setting in buy some HOT SHOT it will help with stiction. Good luck
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #8 of 9 Old 07-27-2013, 06:01 AM
buy some POS dd car to take with you. you will be happier with a cheap car at college. easier to park, no worries about a friend puking in it. cheaper on gas.
post #9 of 9 Old 07-27-2013, 08:46 AM
Quoted: 728 Post(s)
X2. Other jealous retards will vandalize your truck in the community parking lots.
Corey@CNCFAB is offline
Tags
block heater , cold start , cold weather , college
