Turbo Vibrations. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-24-2013, 03:14 PM Thread Starter
Turbo Vibrations.
I have a '03 F350 dually 4X4 7.3, 192,000 miles, there is a vibration in the turbo between 2300 and 2500 rpm and the turbo boost gauge is bouncing all over the place.
Any help/suggestions as to what it could be is greatly appreciated.
Thanks
Reel 007 is offline
post #2 of 10 Old 07-24-2013, 04:44 PM Thread Starter
I am a bit desperate, would like to use the boat this weekend, but will not risk the tow with the noise/vibration and loss of power.
Anyone experienced this problem.
Thanks
Reel 007 is offline
post #3 of 10 Old 07-24-2013, 05:25 PM
I had what's referred to here as 'turbo surge' on my 2000 7.3. Only happened when pulling my fifth wheel up grades, usually in the 16-1800 rpm range. No vibration just a goofy sound from the turbo, sounded like air bouncing around the intake of the turbo. I've read where people have had this surge issue bad enough to bounce the boost needle, mine didn't. I solved my issue by having a different compressor wheel installed on the turbo. It was $89 and cost me $150 to have it installed. I think most folks refer to these compressor wheels as a wicked wheel. Others do ported housings to solve the surge issue but I live in California and can't install one due to smog checks.
Maybe someone here with more knowledge in this area will respond for you.
2000 F350 7.3 4X4 SRW, SC, LB, VDO Gauges, JWVB, PHP Hydra, Tru-Cool Max, KYB Monomax, BTM, BD Brakeloc, S&B CAI, zoodad, WW, Firestone Airbags
cpfullback is offline
post #4 of 10 Old 07-24-2013, 08:07 PM Thread Starter
Thanks.
I just ordered a Garrett GTP38R on line, hopefully that will solve the problem, I am having a bit more than a surge problem, I put the truck in low gear(Drive 2) and rev up to 2800 rpm and it only made ten pounds of boost, and if you try to keep it at that rpm the boost gauge will start going down.
Reel 007 is offline
post #5 of 10 Old 07-24-2013, 08:16 PM Thread Starter
The Garrett GTP38R is a ported shroud housing, I asked the salesperson twice if it met California smog and he said yes.
I am in the inland empire.
Reel 007 is offline
post #6 of 10 Old 07-25-2013, 07:31 AM
Looks like your upgrading your entire turbo, you'll be fine. Some folks install just a new ported intake, like an ATS, on their existing Garrett and that's what not pass the visual smog inspection. Hope that new turbo cures your issue.
post #7 of 10 Old 07-25-2013, 10:04 AM Thread Starter
Thanks.
From the pictures I saw of the turbo I purchased the intake is a ported 4" between the air cleaner and the turbo.
Are you saying if they see that little port it will fail visual smog, and if I replace that piece with one without the port I will be fine.
Thanks again.
Reel 007 is offline
post #8 of 10 Old 07-25-2013, 10:10 AM
timmyboy76's Avatar
from what i'm reading, you just spent about $1500-ish on a turbo, that a wicked wheel would have fixed the issue..(100 buks).
I'm surprised your even making boost, revving it in N. Hell, mine dont move until 3rd gear..(zf6).
From ur original post, it sounds like turbo surge. More air then the turbo can move. Yes, a fix is a bigger/badder turbo or a simple w.w./wicked wheel, would have worked.
And yes, depending on where you go, i believe the 38r WILL fail a visual in CA...but dont quote me
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #9 of 10 Old 07-25-2013, 11:48 AM
I'm not saying you will or won't fail smog and I have no idea whether your new turbo will solve your particular issue...I'm just letting you know that when I had a similar surge issue, I had my mechanic install a WW and that solved the problem for me. I asked him about installing a ported housing and he informed me that he doesn't install them any longer as they tend to fail smog. It seems to me, after going through smog recently and talking to the technician, anything that doesn't look stock and doesn't have a CARB number displayed or is smog exempt is grounds for failure.
post #10 of 10 Old 07-25-2013, 12:38 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
ya 38r's are not smog legal.
the only smog legal aftermarket turbo is made by bd.
your issue of low boost could not even be turbo related.
sounds like you have a boost leak.
torn intercooler boots/manifold etc.
or leaking exhaust up pipes.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
