Old 04-21-2008, 05:56 AM
tran_65 tran_65 is offline
Need some help with heat/cooling
Ok When i turn the heat or air conditoner on I only get air out of the window defroster no matter what setting the control nob is on. I would like some insight/guesses on as to why i can't get any airflow to the vents or floor thanks.
Old 04-21-2008, 06:28 AM
pwrstrokinrebel pwrstrokinrebel is offline
Send a message via AIM to pwrstrokinrebel
there might be a plug unplugged under the passenger side dash. it is a triangular plug check that. it has come unplugged in my truck several times
Old 04-21-2008, 07:37 AM
kainers kainers is offline
Check your vacuum pump.It is a little black unit on the passenger inner fender well.Fallow the vacuum line to it.Make sure it is plugged in and with the truck running it should be also.I don't know anyother ways to check it.Check for vacuum leaks and If your truck is 4X4 I bet the hubs don't engage if they are auto hubs.
Old 04-21-2008, 09:10 AM
USAFdieselman USAFdieselman is offline
Proud daddy!
Your system is in the default setting, you have a vacuum leak somewhere. Check the pump and all the lines under the dsah to make sure they aren't unplugged or broken.
