Old 04-18-2008, 06:45 PM
Motown Fire Motown Fire is offline
Question Fuel/Water Drain Part # ???
What is the part number for the Fuel/Water Drain that mounts to the back of the fuel filter housing??? Mine is leaking and I need to replace it.
Old 04-18-2008, 06:50 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Replace the orings first Go to a hydraulic shop and ask for Viton #202 O-rings 1/4" I.D.- 1/8" cross-section.
Old 04-19-2008, 05:05 AM
NCHornet NCHornet is offline
Powerstroke Techie
For a part # just go to Fordpowerstrokeshop.com and look it up. The O rings are a lot cheaper, but the complete assembly is around $35 IIRC not a bank buster.
NCH
Old 04-21-2008, 12:14 AM
militaryman3756 militaryman3756 is offline
its the orings, easy fix in about 30 mins. for only like 5 bucks
Old 04-23-2008, 04:31 AM
alabamafrog alabamafrog is offline
Powerstroke Techie
Viton O-rings 1/2" OD 1/4" ID 1/8" thick. I got mine from a parts store for like $5, I've seen them on eBay. Any hydro shop or hardware store should have them. You'll need a torx bit to get it apart. A 1/4" air ratchet is nice too. Oh and definitely lube them good before reinstallation.
Old 04-23-2008, 02:56 PM
camptoboat camptoboat is offline
I got my o rings at Ace Hardware for around a buck each.
E-mailed their suppler and they said they are viton type.
No run, no drips, no oh sh**s
