Old 04-18-2008, 02:45 PM
jbetzelb jbetzelb is offline
Chip install
How long does it take to install a TS Chip? Lame question I know but I have 4 or 5 hours tonight but I need the truck tomorrow morning. I am a fairly decent gear head. I turned around a water pump install on it in 2.5 hours for example so you can kind of judge ability. Where have you guys mouted the 6 pos knob at? I prefer to keep holes out of the dash.
Old 04-18-2008, 02:49 PM
Dave Dave is offline
Obama sucks
You should be able to do it in a couple hours easily
Old 04-18-2008, 02:52 PM
Goose Goose is offline
Sponsored By MOM
Send a message via AIM to Goose Send a message via Yahoo to Goose
actually about an hr if you can do that very simple
Old 04-18-2008, 02:56 PM
lords88 lords88 is offline
All you need is a 10mm socket to undo the bolt under the hood that connets all the wring to the computer and then a 7mm socket to take the two screws that hold the PCM in place. Clean the connections on the PCM attach the chip put it back together and you are ready to roll!
Old 04-18-2008, 04:32 PM
mnstroker mnstroker is offline
Hardest part is getting your arm in there to take out the bolt
Old 04-18-2008, 06:43 PM
73LSTROKER 73LSTROKER is offline
Don't forget to keep the key in your pocket!!!! If you fry your PCM it could be a very timely install.
STROKER
Old 04-18-2008, 07:03 PM
GoldieStroker944 GoldieStroker944 is offline
yea i would also un plug the batteries too and make sure that your connections are clean i had some problems with that and also you might want to put some electrical tape over the chip to hold it in the pcm tight i didnt do this right away and i got left stranded lol
Old 04-20-2008, 08:16 PM
Thanks all. About a hour and 20 minutes just like you all said. Holy smoke, the org isn't kidding when they say you need a chip. On the 100 horse setting at 30 mph the thing busted the back tires loose and it started haning sideways for a while. I assume my stock exaust and intake make the 140 setting only for a smoke show? The 100 horse setting is as fast or faster.
Old 04-20-2008, 08:18 PM
yea i have the same chip and i think the 100 is faster but the 140 is fun to dust ricers lol haha the only thing i noti ced if you change the settings alot your trannie will start doing funny things but i jsut leave it for while and all is good just some more info for ya
