  #11 (permalink)
Old 04-19-2008, 07:29 AM
RC51 RC51 is offline
cj41foleyisathief
Originally Posted by rednekexprez View Post
leave the centers off and paint your hubs black...It will look tuff..
X2 it will look
  #12 (permalink)
Old 04-19-2008, 10:35 AM
scagle1 scagle1 is offline
Cut em'...I ordered my wheels and tires and they showed up with solid centers, As soon as i saw this i called discount and they put the correct ones in the mail.In the meantime my buddy was getting his tires and they came with solid too.Well mine are kinda contoured to match the wheels and the new ones were smooth so i passed the open ones on to him and rotozipped mine with an open circle in the middle.Works great
  #13 (permalink)
Eric Eric is online now
I HAVE POWAH!!!!!
You don't have to have KMC caps. Just get some black open ended caps. All you need is the hub bore.
  #14 (permalink)
Old 04-19-2008, 02:54 PM
USAFdieselman USAFdieselman is offline
Originally Posted by NCHornet View Post
Oh I see what you are talking about. You aren't suppose to use the center caps with a 4x4. I thought mine looked terrible, and I didn't want to chance taking a hole saw to a expensive center cap, besides I don't think just cutting a hole in the center cap is going to look much better. Here is what I did and it has worked awesome!! Mount the wheels without center caps on. On my center caps they inserted from behind and had three or four little flanges that would keep the cap from passing all the way through. I cut these off and smoothed the edges. Then I took 1/2" strips of good duct tape and started wrapping the bottom edge, but a couple layers on and insert it from the outside pushing it in towards the hub, if it is too loose put another layer or two. You want a good snug fit. I have the ESOF system and keep it working properly so I have never had to use the manual lock outs, if I ever need to, all I have to do is grab the center cap and give it a wiggle or two and it pulls right off. The guys at the tire shop thought it looked pretty slick. This has worked for me so I thought I would pass it along.
NCH
Damn thats a hell of an idea! Guess my front center caps will be going back on!! WOOHOO!! Thanks!!
  #15 (permalink)
Old 04-21-2008, 03:46 AM
NCHornet NCHornet is offline
Powerstroke Techie
It worked for me and it looks awesome!! You also don't have all the crud getting into the hub lever, so it does double duty!!!!
