  #11 (permalink)
Old 04-16-2008, 06:09 PM
CoalRollinRoosterCruiser CoalRollinRoosterCruiser is offline
Freedom Ain't Free
Send a message via AIM to CoalRollinRoosterCruiser
Originally Posted by xsracinggt View Post
My truck manufacture date is 6/98 so that makes it an early 99. The valve covers say its a 99, even says she base HP is 250. I thought the BHP for mine was 235. I dunno. Any how, I will check the HPOP out tommrow. WHere is the inspection place for the rods? Can I inspect them with out fear of losing oil or other fluids?
That is very weird. I didn't think the 99 had 250hp either. My sticker on my truck(which of course is a 2000) says 235.
I know the 03's were 275hp.
I think maybe the 01 or 02's were 250hp?
That still doesn't explain yours saying its a 99, but saying 250hp.
And here's the link for finding out which rods you have!!
7.3 Inspection Hole for Powdered Metal Rod Determination
  #12 (permalink)
Old 04-16-2008, 06:48 PM
HVAC SuperTech HVAC SuperTech is offline
Scott loves the Squirell
Thank you sir!! (Coach Carter) hehe
Yeah, My engine has a mind of its own. hehe...I am still wondering why I have low Oil pressure.
  #13 (permalink)
Old 04-17-2008, 06:18 AM
alabamafrog alabamafrog is offline
Powerstroke Techie
Here is the sticker from my early 99
  #14 (permalink)
Old 04-17-2008, 06:20 AM
Powerstroke Techie
You do know that the factory engine oil pressure gauge is not really a gauge, it’s just an idiot light, either on or off at around 9 psi, happy or not happy. I installed an actual gauge on mine and the pressure varies from 40 psi to 100 psi with rpm and temp. Or are you talking about HPOP oil pressure?
  #15 (permalink)
Old 04-17-2008, 12:55 PM
Freedom Ain't Free
He wasn't refering to the factory, dummy guage.
He's got an aftermarket oil pressure guage in the truck.
Heres what he told me about the problem.
It reads about 50-60 when its cold, and after complete warm up, it reads 15 at idle, sometimes 10. When I mash it, it usually goes to 25. It should be 50-70. I have this squealing sometimes, rare tho. I also hear a slight low thump thump comming from what sounds like the front of the engine. I was told by Matt at Spartan Deisel, here in h'ville, that that was my HPOP making that sound cause it was low on oil. Which would mean the Low oil pressure pump aint keeping up. I replaced it, and it corrected it for the most part. You would really have to take a hell ride in the truck to understand. I will be glad to show you anytime. I wanna get Scuffy828 on this problem, but he needs to have the truck in his possesion to properly diagnose it.
  #16 (permalink)
Old 04-17-2008, 04:21 PM
southmike southmike is offline
what about the turbo..
if you can bearly tick your hand behind it it is a late.
if your haed almost fits it is an early..
if it surges it is a late....
hpop res can be increased, I have even seen a mod that runs an extra line up there
  #17 (permalink)
Old 04-22-2008, 11:16 AM
I have an early 99 turbo, pedistal and intake Y pipe. I reached behind the HPOP and felt and it was flat. No rise in th middle. so that tells me I have a 15* pump. But I know my engine oil pressure is low. way low. I do have a leak on the CCV mod i did when I turned the CCV thing on top of the valvecover around backwards. SO I have to fix that oil leak. Thats one of the bigger ones. I have diagnosed my rear main is leaking too most likely. I cannot find a trail down to the back of the engine, but all around the inspection plate on the trans is covered in fresh oil, and so is everything behind it. UGGGGGGHHHHHH!!
  #18 (permalink)
Old 04-22-2008, 11:24 AM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
What is it that makes you believe your HPOP pressure is low? Have you data logged some runs?
Here is a little good reading and a how to for a DIY HPOP gauge:
http://www.swampsdiesel.com/content/faq/hpop.htm
  #19 (permalink)
Old 04-23-2008, 06:49 PM
I dont think that my hpop is low, I think(know) my engine oil pressure is low. I think my HPOP is fine. I just think that because the low pressure pump is not producing, or holding pressure like it should(due to unknown reason, but I did just replace the pump), its not keeping the HPOP resivior filled all the time on WOT runs. Therefore, the HPOP cant keep up with demands of the injectors because of something prohibiting the Engine oil pressure(or volume) from being high enough. Did I explain that correctly to you? I got confused typing it!
