Old 04-15-2008, 08:57 AM
onecrazyblackredenck onecrazyblackredenck is offline
codes
I had my computer scanned and here is the codes I have thrown, P0470 and P0541.......I also have a pmt1 instead of stock pcm......
Old 04-15-2008, 09:11 AM
Doakster Doakster is offline
Here is a link to all PSD codes.
Powerstroke Codes
Old 04-15-2008, 09:13 AM
Exhaust Back Pressure Sensor Circuit Malfunction and Manifold Intake Air Heater
what do they mean??
Old 04-15-2008, 09:33 AM
Usually when you get an EBP sensor malfunction that could me one of two things or both, 1) the EBP sensor is not working, 2) The tube that connects from the front of the passenger side exhaust manifold to the EBP could be clogged (very common). When this code pops up usually it is suggested to put a new EBP sensor in and clean the tube or replace with the tube with a new one. The EBP sensor is located directly infront of HPOP reservoir. I did this replacement about 4 months ago. Cheapest place on these parts will be Powerstrokeshop.com
I'm not 100 percent sure on the AIH code, but I would guess it would be either the AIH relay is bad, or the AIH is bad it self.
Old 04-15-2008, 09:58 AM
Here is a right up on the EBP sensor replacement.
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Old 04-15-2008, 10:02 AM
Here is guzzles code list too, a little more comprehensive and a little more explained.
Welcome to guzzle's Diagnostic Trouble Code list Web Page
