  #31 (permalink)
Old 04-15-2008, 01:34 PM
Marty Marty is offline
International Threat
Originally Posted by forddieseltweek View Post
Crower rods,
Comp High rev valve springs,
Comp cam,
H-11 head studs,
Fire rings,
South Bend double disk clutch
6.0 intercooler
This summer,
Custom compound turbo set up by Elite Diesel 65+lbs of boost
Auto trans swap (BTS or Allison 6 speed auto)
Solid axle Swap
Lockers front and rear
Beans fuel system
Pulse HPOP
Nitrous.....
What do you guys think?
Forget the cam, get a girdle/mainstud kit in there.
Add chromoly push rods to your list.
Skip the DD clutch if you're swapping in an automatic later.
Reason for lockers over true-trac's?
Forget the allison - the 4R100 is a much better tranny when built by BTS.
Why compounds? Unless you plan to go with bigger injectors - there really is no reason.
What comes off the top at the moment
  #32 (permalink)
Old 04-15-2008, 07:04 PM
lukecline
Tournaments Won: 1
Posts: n/a
I am pretty positive that it will work on the Early 99...
Your d66 will not work on an early 99, the pedistals and up pipe collectors are different.
  #33 (permalink)
Old 04-15-2008, 09:22 PM
forddieseltweek forddieseltweek is offline
Where do I chromoly push rods?
I am getting the girdle and mainstud kit also, I will go with B-codes and a Pulse pump when I do the compounds this summer.....
  #34 (permalink)
Old 04-15-2008, 09:30 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
You can get them from Wipe Out Enterprises, Wide Open, Black Widow or Diesel Innovations. Orrrrrr you can send one of them to smith brothers and have them make them for you for $11 each. That is where half the names above get them made.
Oh yah, loose the SCT and get some real tunes....
Smith-Brothers Pushrods
Smith Brothers Pushrods
HEAT TREATED 4130 CHROMOLY FOR EXTREME SPRING PRESSURES
NH38B NA HT 3/8 X .083 BALL/CUP & BALL 10.99
  #35 (permalink)
Old 04-15-2008, 09:51 PM
Is that the part number for them?
  #36 (permalink)
Old 04-15-2008, 10:09 PM
strokerboy73 strokerboy73 is offline
Originally Posted by alabamafrog View Post
That sponsoring thing is cheating!
It cost me 4G’s to build mine back nearly stock and doing all of the work myself.
Jealous?.........I AM!!! lol. So you are one lucky bastard.
  #37 (permalink)
Old 04-15-2008, 10:12 PM
2005F250 2005F250 is offline
So will the stock engine mounts hold up? Or will the pull force of the fan rip the engine out of the front of the truck?
  #38 (permalink)
Old 04-15-2008, 10:13 PM
That is from their price sheet. Chromoly, heat treated, thicker wall tubing. That part number is only the material description. The lenght is depending on your application. You will need to send them a pushrod from your truck to match so all the things get matched perfect like the ball diameter, oil hole diameter and over all lenght.
  #39 (permalink)
Old 04-15-2008, 10:25 PM
I will get them when I do the Compounds....
