Old 04-14-2008, 10:52 AM
Speedyboy487 Speedyboy487 is offline
Berm Buster
Boost ?
I cant seem to get my boost above 17. With my hyperpac on stage 3 and the waste gate unhooked it will reach 17.26 and trip the engine light and defuel, it even did this when the waste gate was still hooked up. then the boost drops down to about 12 or so and stays there. I know a boost fooler would prolly do the trick but i have seen other trucks reach much more without one. It also does it on stage 2. With the red line unhooked it does build boost quicker but i didnt see any overall gains in boost.
Old 04-14-2008, 11:05 AM
CSIPSD CSIPSD is offline
Check your up pipes for leaks, all your IC pipes for loose connections and add a Regulator from ITP...
