Torque app for android - Page 4 - Ford Powerstroke Diesel Forum
 1Likes
post #31 of 41 Old 08-23-2013, 04:01 AM
anyone know if there is a double-din head unit that will sync with your phone so you can display the torq-pro app via the receiver? im probably asking for way to much lol.
2002 F350 CC Auto 2x4 SRW SB
jhobbs26 is offline
post #32 of 41 Old 08-23-2013, 07:39 AM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 37 Post(s)
There are a couple android based double-din unit's on Ebay that I've been tempted to try, but - most were Older 2.x androids OS's. I'm waiting to see if there's at least anything in the 4.x Android before I consider them.
*Edit.
Also - most of them are form 'Over Seas".... but after a quick search - I'm seeing some that are Android 4.0 now...
**Edit #2.
Ok, this just got added to my watchlist!!!!
7in LCD, Android 4.0 and the faceplate is a detachable tablet...
http://www.ebay.com/itm/Detachable-T...t_20743wt_1161
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
post #33 of 41 Old 11-12-2014, 07:00 PM
Grizz64's Avatar
I know this a old thread but did you go with the Torque pro app.
If you did can you tell me what gauges I should be watching. I will be setting mine up in a few days.
PS. I have a 2005 F250 SD.
Grizz64 is offline
post #34 of 41 Old 11-12-2014, 09:57 PM
Quoted: 861 Post(s)
Feedback Score: 3 reviews
The most important ones for a 6.0 are your voltage deltas and your oil/coolant deltas. And of course your ICP and IPR.
Corey@CNCFAB is offline
post #35 of 41 Old 11-13-2014, 05:36 AM
TwinTurbo6.4's Avatar
Quoted: 82 Post(s)
Here is another Torque App thread. It has some good info/pictures in it.
Torque App Photos
'08 F250
H&S Mini Maxx w/ Cale Thompson tunes, FloPro 5"/EGR Delete/Cold Side Pipe, Pillar Gauges and CTS2,
Gear Alloy Big Blocks 20x12 -44, RetroFit Headlights - Morimoto Mini H1's
TwinTurbo6.4 is offline
post #36 of 41 Old 11-13-2014, 05:41 AM
Msp079's Avatar
Quoted: 52 Post(s)
What is reasonable numbers for monitoring your ICP & IPR...I have had the app for quite awhile and use it now and then.....
Can I get a base line of good numbers for the most essential gauges.?
Any help is much appreciated, because then I can get a base line if something is wrong in my truck.
Wanted to add to what numbers your you putting in on the settings page to get a proper boost reading?
2005 F350 Harley Davidson Edition CCSB SOLD!!!
Icon Vehicle Dynamics 4.5" stage 4 lift, 37x13.5R20 Toyo Open Country M/T, 20x10 Fuel Throttle wheels, ARP headstuds, EGR delete, MBRP 5" powdercoated turbo back exhaust, wicked wheel, Blue spring mod, Mishimoto Radiator, oil cooler, stand tubes and dummy plugs, Sinister Diesel coolant filter, 6.4 banjo, Air Raid air filter, SCT X4 tuner with tunes from Innovative Diesel, EGT, HPOP, fuel pressure A-pillar gauge pod
Msp079 is offline
post #37 of 41 Old 11-13-2014, 08:44 AM
Grizz64's Avatar
Hucorey, if you could provide a range of numbers we should stay within that would make you awesome. If not, well we'll have to start a new thread. LOL
Thanks and it's snowing hard here.
Grizz64 is offline
post #38 of 41 Old 11-13-2014, 09:02 AM
Quoted: 861 Post(s)
for a 7.3
ICP idle 450-550 highway cruising 1000-1500 WOT 2500-3500 (below that pump is starting to get weak or not enough to supply bigger injectos
IPR idle 6-10% highway cruising 20-30% WOT no more than 65%
post #39 of 41 Old 11-13-2014, 09:05 AM
Quoted: 861 Post(s)
stay as close to 48V as possible. I know if you get much below 47V or into the 50V range you'll fry your FICM and then toast your injectors.
oil/coolant deltas keep within 10* typically. There are some guys on here that have been running around 15* delta for years and no issues, but as we know, each truck really is different.
post #40 of 41 Old 11-14-2014, 02:11 AM
ryanbr72's Avatar
I may have to try this again, got it this summer but couldn't get it to read anything but rpms at the time. Just may have to play with it again.
ryanbr72 is offline
