new mc still no brakes - Ford Powerstroke Diesel Forum
post #1 of 20 Old 07-08-2013, 04:50 AM Thread Starter
miked.'s Avatar
i feel like i am beating a dead horse. replaced the master cylinder and the brakes were back to normal. got in it this morning to go to work and pedal goes to floor again no brakes. i am going to bleed the calipers again just make sure. anything else i should check? abs sensor?
miked. is offline
post #2 of 20 Old 07-08-2013, 06:08 AM
Quoted: 722 Post(s)
Did you bench bleed the MC first before you installed it?
Corey@CNCFAB is offline
post #3 of 20 Old 07-08-2013, 08:24 AM Thread Starter
miked.'s Avatar
yes. and i just finished bleeding the entire system master cylinder included, and still no brakes. going to bleed it again in a few minutes. note i used a hand vacuum pump to bleed the system because i am by myself.
miked. is offline
post #4 of 20 Old 07-08-2013, 08:38 AM
Quoted: 722 Post(s)
I have only heard of this but sometimes a vacuum pump doesn't always do that good of job. I've never used one as I a have always had someone around. The wife.
post #5 of 20 Old 07-08-2013, 09:31 AM Thread Starter
miked.'s Avatar
think you may be right. i used a hose from the bleed screw to bottle of trans fluid. i pumped the brakes with the engine off. had a good pedal all the way a round. then when i started the engine the pedal went to the floor and no brakes. how often does the abs get air in it?
miked. is offline
post #6 of 20 Old 07-08-2013, 05:32 PM Thread Starter
miked.'s Avatar
bled brakes again and noticed fluid coming out of power steering pump reservoir. why?
miked. is offline
post #7 of 20 Old 07-08-2013, 05:35 PM
Quoted: 722 Post(s)
Trans fluid I hope. Did you or someone turn the steering wheel while you were bleeding the brakes?
post #8 of 20 Old 07-08-2013, 05:37 PM Thread Starter
miked.'s Avatar
yes i think i did out of frustration
miked. is offline
post #9 of 20 Old 07-08-2013, 05:38 PM
Quoted: 722 Post(s)
That's normal when the truck isn't running.
post #10 of 20 Old 07-08-2013, 05:54 PM
RetiredFD's Avatar
You may need to have someone help you or just let them gravity bleed for a while.
- Chris
2006 F250 CCSB Lariat
RetiredFD is offline
