Plasti dip your idm to protect it? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-07-2013, 08:32 PM Thread Starter
Eco Taxi's Avatar
Ok I was talking to a few people about protecting the idm. I've heard stories about idm's getting wet then getting replaced and was curious about using plasti dip to nip that possible future problem in the butt.
I understand you wouldn't be able to dip the idm completely because there's the harness connection point but otherwise I can't think of any other issue.
Thoughts?
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #2 of 4 Old 07-08-2013, 12:52 AM
alaskan155's Avatar
Quoted: 60 Post(s)
after looking at this thread
IDM Mod 140 volt - Ford Truck Enthusiasts Forums
never looked at the idm before,
i honestly see no reason you can't, i dont see any cooling vents on the case/ its already rtv on the cover(to seal it)
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #3 of 4 Old 07-08-2013, 11:32 AM
rascal's Avatar
Dumb question.
Where is the IDM located?
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #4 of 4 Old 07-08-2013, 11:37 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Originally Posted by rascal View Post
Dumb question.
DS fender!
2000-7.3L is offline
