engine coolant - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-06-2013, 08:15 PM Thread Starter
engine coolant
I bought some peak longlife a year ago and it's sitting on the shelf. Can i use this in my 02 f 250 7.3? It has the ethglene glycol an drethylene glycol in it and meets the ASTMD -3306 and -4340 specifications. Or do I just need to see if they will take this back and get something else. This is not the 50/50 mix it is the straight concentrate.
scrnt is offline
post #2 of 6 Old 07-06-2013, 08:47 PM
timmyboy76's Avatar
if its this... PEAK | LONG LIFE | Antifreeze / Coolants | Auto Products take it back.
You want this, if staying with PEAK Final Charrge...Peak Commercial & Industrial
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 6 Old 07-07-2013, 04:01 AM Thread Starter
Thanks I will be taking it back.
scrnt is offline
post #4 of 6 Old 07-07-2013, 10:35 AM
timmyboy76's Avatar
Here is a list of ELC's that would work:
CAT HD ELC
Fleetrite HD ELC (International's brand)
Rotella HD ELC
Prestone HD ELC
Zerex Extreme HD ELC
Chevron/Texaco/Delo ELC
The latest formulation of the Delo ELC has a maintenance-free change interval of 750K miles/8 years or 1M miles with an extender.
Chevron DELO ELC is the bomb!
Fleetrite / Rotella ELC : The Rotella is the same exact stuff as the Fleetrite, just in different bottles and it's the best type of coolant to use. Just make sure you do a proper flush and use distilled water.
Zerez Extreme Duty (RED)...you can get it at Napa. It is already pre charged and doesn't require any monitoring or additives.
FYI, there are two types of SCA. DCA-2 and DCA-4.
NapaKool is a DCA-2 SCA.
DCA-2 is a Nitrite-only based SCA. Nitrite is the primary and most effective cavitation inhibitor in any SCA. DCA-2 usually contains potassium buffers, free of phosphate.
DCA-2 was the first SCA, and it remains the most popular. It can be tested with any test strip that shows Nitrite levels, either a 2-way or 3-way strip.
DCA-4 is a Molybdate/Nitrite based SCA. It uses both Molybdate and Nitrite "synergy" as a cavitation inhibitor. DCA-4 usually has sodium buffers and phosphates.
DCA-4 is somewhat harder to find, maintain, and optimize. It can be tested with a 3-way test strip, although conversions are available for using 2-way strips.
post #5 of 6 Old 07-11-2013, 10:25 PM
bronco73's Avatar
I am confused. I bought Zerex Extended Life Heavy Duty Formula red coolant. Says " Diesel Ready fully formulated for use in the following applications CAT-EC-1. Is this o.k. to put in my 02 diesel?
bronco73 is offline
post #6 of 6 Old 07-12-2013, 05:35 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
Yes that is fine. Cat EC-1 and Cummins 14603 are considered the "ELC" standards.
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
