Battery Light - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-06-2013, 06:46 PM Thread Starter
Battery Light
Hello: 06 f350, new batteries a month ago, truck has been starting great. Now battery light came on, tested batteries while running scan gauge reads 13.8 - 14.2, tested batteries while off both read 13.1, tested batteries while running with lights on and ac, hazard, still reads 13.8. Removed lower alternator and had it tested, failed bench test. Replaced it with new ford alternator. Truck fired right up, drove 10 minutes and battery light came on. Scan gauge still reads 14.1 . Light is driving me crazy, any thoughts....Thank you.
dinos is offline
post #2 of 8 Old 07-06-2013, 07:00 PM
The battery light usually only comes on if its the batteries or alternator I believe. You said you replaced the lower alternator, what about the upper.
I cant imagine that the light would come on unless something is wrong or you have aftermarket alts. I have heard of autopart store alternators making the light stay on but you said yours was oem.
Im sure someone will help you figure it out. Are you sure you got the connector all the way on?
I recently replaced mine with a bosche from napa cause it was an emergency situation. I thought the connector was fully seated but it wasn't. It worked fine for a little bit but the connector came out enough to make the light come back on. It was a pain to get the connector fully seated. I would check that, idk
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #3 of 8 Old 07-06-2013, 07:39 PM
Quoted: 727 Post(s)
I guess have the other one tested too. Then go from there. Or just unplug the other one unless they both have to be plugged in.
Corey@CNCFAB is offline
post #4 of 8 Old 07-06-2013, 07:47 PM
usnavyad's Avatar
Feedback Score: 3 reviews
Normally if both batts are good it's the alt
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #5 of 8 Old 07-08-2013, 08:15 PM Thread Starter
Well replaced second alternator and batt light went off. Thanks.....
dinos is offline
post #6 of 8 Old 07-08-2013, 11:22 PM
Glad you got it resolved but I bet the wallet is hurting a bit.
INFRNL is offline
post #7 of 8 Old 07-09-2013, 02:23 AM
Quoted: 727 Post(s)
What he said. I supposed that's one bad thing about having a dual alt setup. Strange that both would go bad.
post #8 of 8 Old 07-09-2013, 06:36 PM Thread Starter
Thanks guys, finally no batt light and no money!! Gotta love our fords.
dinos is offline
