2002 7.3L Won't stay running! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-05-2013, 11:54 AM Thread Starter
I have a 2002 F205 7.3L Diesel. The other day i was driving normally down the road when i quit. Just like i shut the key off. It wouldn't start. Let it sit about 1 hour and tried it and it started up. (no codes showing) I thought it was the ICP sensor so i changed it. still the same problem. Then i tried spraying water on the motor to cool it then it would start right up, but die when it warmed up. I narrowed the spot to the HPOP. I can pour just a little water down there and it will start right back up. Could it be the IPR or a bad HPOP, or ICP sensor? Thanks, Daniel
dkoehn is offline
post #2 of 13 Old 07-05-2013, 12:31 PM
timmyboy76's Avatar
looks like you got one of them, hydro 7.3's.
i think its coincidental. Your symptom is similar to a CPS sensor going bad. You already should have a spare in the glovebox, anyhow. Start there and proceed. With no codes, it cant be something major.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 13 Old 07-05-2013, 12:58 PM
scslucky13's Avatar
Sounds like it could be a CPS (Cam Position Sensor). Mine did that a couple years back I changed it and haven't had a problem since. Make sure you get one from ford I changed mine with one from Napa and it lasted maybe six months. They are not to pricey and easy to change. Front of the engine you'll see it by the crank pulley has one bolt holding it in I believe it takes a 10mm socket, swap it and you should be back on the road.
99 F250 7.3L
Diesel Dynamics Chip (80hp)
DIY Cold Air w/ 6639
ATS Compressor Housing
Zoodad Mod
CCV Mod
Hutch Mod
Carter Helper Pump
AIH Delete
HPX
TC Lockup Switch
4" Straight Pipe
Auto Meter Ultra lites
(Pyro,Boost,Trans Temp)
scslucky13 is offline
post #4 of 13 Old 07-05-2013, 04:37 PM
mine did the same took it to the mechanic he had it for a week no codes the night before I go get it it did the same to him it was the ipr changed it out 2 months ago no troubles since hope this helps.
scrnt is offline
post #5 of 13 Old 07-05-2013, 08:52 PM Thread Starter
Thanks for all the help
I changed the CPS, but it was from O'reilly auto parts. No change.....
do you think it is bad also?
Thanks
dkoehn is offline
post #6 of 13 Old 07-05-2013, 09:25 PM
I tried one from Oreilly AP too, and it ran worse than before. I had already ordered some on Ebay ' - parts_master''s Emporium - eBay Motors' they showed up the next day, and since I installed the black colored CPS, no problems.
2001 F350 Lariat 7.3L 4x4 CC SB
BFG-AT 35x12.50R16.5, 4" Lift 173,000mi...so far
RafterQ is offline
post #7 of 13 Old 07-06-2013, 07:02 AM
Eco Taxi's Avatar
Check this one out - new international "black" one
Improved Blue CPS for 7.3L Ford Powerstroke Diesel
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #8 of 13 Old 07-06-2013, 09:47 AM
7.3550Duty's Avatar
With those CPS, you have to run a OEM ford one or your truck will run twice as bad as before. They aren't nearly as expensive as they once use to be. Like less than $20 so make the trip to a ford dealer and get one, buy a spare one to keep in glove box
Robert
01 F350 CCSB
a few mods
7.3550Duty is offline
post #9 of 13 Old 07-08-2013, 06:32 PM Thread Starter
Ok, I just changed the CPS out with F7TZ 12K073 B . From Ford....
No change.... any more ideas?
Thanks, Daniel
dkoehn is offline
post #10 of 13 Old 07-08-2013, 06:33 PM Thread Starter
You think it's the IPR?
Thanks, Daniel
dkoehn is offline
