degreaseing the turbo? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-04-2013, 02:21 PM Thread Starter
got the turbo off and need to clean it . just want to get the grease and crud off the housing . i sprayed it with purple power,can the pressure washer be used on that?
06 f350 super cab dually SOLD.
02 f350 ext. cab Lariat . 6637,edge insight cts,plenum inserts, riff raff boots ,diy ccv delete, IH up-pipes
walleyecat is offline
post #2 of 2 Old 07-04-2013, 03:17 PM
Yep it won't hurt the outside at all. I just wouldn't spray directly into the housings.
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
