What is in my coolant? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-04-2013, 01:39 PM Thread Starter
jvanwalsen's Avatar
Hey guys newbie here. Power washed my motor and tranny and only leaks I found were the tranny pan gasket and the place where the dipstick tube enters the oil pan. But today went out to look around and took off the degas lid and looked inside, this is a pic I took looks like gasket material? Any help?
jvanwalsen is offline
post #2 of 9 Old 07-04-2013, 03:21 PM
Looks like rusty/cruddy buildup to me. I'd flush it and see if its still there.
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #3 of 9 Old 07-04-2013, 03:26 PM Thread Starter
jvanwalsen's Avatar
I took a piece out actually feels rubbery like make your own gasket material
post #4 of 9 Old 07-04-2013, 06:53 PM
Richie Rich's Avatar
I wonder if its the "fix a head gasket" crap you get at vatto zone
2003 F250 CCSB 4x4 XLT with leather
7.3 Powerstroke with 98k miles
Ford AIS Intake
Zoodad Mod
4" Turbo Back Exhaust
Foil Delete
Rebuilt trans at 82k
Richie Rich is offline
post #5 of 9 Old 07-04-2013, 08:13 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
Dang that looks a little scary. Might wanna start saving for a possible water pump replacement. I'd try to get as much of it as you can, flush, fill, install coolant filtration, hope for the best.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #6 of 9 Old 07-04-2013, 08:49 PM
ZMANN's Avatar
Quoted: 1564 Post(s)
RTV squeeze out from a repair ?
could Be a stop leak ? but I haven't seen one that looks like fish flakes myself then again I have only used Aluma Seal and that was ages ago
We Miss you Ronnie
ZMANN is offline
post #7 of 9 Old 07-04-2013, 09:47 PM
Lilfarmrboy's Avatar
Have you owned this truck from day one or did you buy it used? Needless to say I wouldn't worry, just flush it. If it comes back after a good flush then I would worry.
Lilfarmrboy is offline
post #8 of 9 Old 07-05-2013, 07:21 AM
timmyboy76's Avatar
Welcome to guzzle's Coolant Bypass Filter Mod Web Page
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #9 of 9 Old 07-06-2013, 06:09 AM Thread Starter
jvanwalsen's Avatar
I did by the truck used has 218000 on it I know from paperwork he had all new injectors, new turbo and pedestal, new valve cover gaskets and new oil cooler with lines and new transmission lines. Just wonder if any of these could have contributed that material into the coolant?
