01 F350 front springs worn out? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-03-2013, 11:59 AM Thread Starter
700hauler's Avatar
Hey guys. Finally got my Dad's F350 home with me. I LOVE this truck! I REALLY want to level it out and get some bigger tires under it. However I'm kind of curious as to whether the front springs are shot or not..? And I want to find out as it will help me decide as to which route to take to level it. The front sits ~4.5" lower than the rear (measured from ground to top of fender well front and back). Here are a few pictures:
Overall stance:
Front springs driver side:
Front springs passenger side:
rear block(s?):
Thoughts?
700hauler is offline
post #2 of 10 Old 07-03-2013, 12:01 PM Thread Starter
700hauler's Avatar
My first thought is that they are in fact worn out and need replaced. So that pushes me toward the option of getting two front aftermarket spring packs designed to lift the front. Or should I get some X codes and do a hanger/shackle kit? Or should I roll with them as is and just do a mini pack kit in conjunction with whats already there? hmmmmmmmmm
Any input is greatly appreciated!
post #3 of 10 Old 07-03-2013, 05:16 PM Thread Starter
700hauler's Avatar
...nobody?
post #4 of 10 Old 07-03-2013, 06:55 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
they dont look like they are sagging.
so either go with a mini spring pack or shackle lift.
i have replacement springs but they are pricier.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #5 of 10 Old 07-03-2013, 07:46 PM Thread Starter
700hauler's Avatar
Are they supposed to be flat?
post #6 of 10 Old 07-03-2013, 10:26 PM
Yes they are usually flat or have a slight negative arch. I left you some info as you probably saw on psa
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #7 of 10 Old 07-04-2013, 03:08 AM
Quoted: 859 Post(s)
Feedback Score: 3 reviews
X codes alone will give you a nice level kit look. They don't ride any different either. They cost $110ea. Spring packs are a cheap arse way around from people using blocks which are illegal to run on front axles. Running spring packs/blocks will give you more axle wrap when in 4x4.
Look on YouTube for powerstroke axlewrap and you'll see what I mean. Fwiw Dan @ Carli explained this very well to me.
Corey@CNCFAB is offline
post #8 of 10 Old 07-04-2013, 04:50 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Where are you finding stock springs for $110? That's cheap...
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #9 of 10 Old 07-04-2013, 04:56 AM
Quoted: 859 Post(s)
Ford does not make their own springs. They are sub'd out to a Tier one supplier. I got mine from thesuspensionkings.com or sdtrucksprings.com I don't remember .
post #10 of 10 Old 07-04-2013, 05:36 AM Thread Starter
700hauler's Avatar
Thanks for the info guys
